help with a/c motor - Defender Source
Old April 11th, 2005, 09:25 AM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
help with a/c motor
Hi,
I'm tring to remove and repair(replace) my a/c blower motor. It is making a really load noise and stops and starts. I have a 1994 but it has the 95 a/c system. The manual I have doesn't have any illustration on how to remove this. I removed the four(two on each side) screws from the condensor cover but it won't come off. Can you drop out the motor w/out removing the condensor cover?
Thanks for the help.
Rich
Old April 11th, 2005, 03:28 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
It seems like when my unit was taken out, the lower part of the cover went with it. I have a '94 Diavia system.
"Uhh...I think they all leak like that."
Old April 11th, 2005, 03:36 PM
IIRC you have to take off the vent assembly (easy, just pop the vents and remove the screws that hold it to the dash), then you remove four more screws attaching the condesor/blower to the dash, then you lift the condensor/blower assembly out as a group. There might be two more bolts securing it to the footwell, but they weren't used on mine. I've sold the unit, so I'm working off memory.
Old April 12th, 2005, 12:25 PM
Campbell's Avatar
Campbell
Rich Campbell
Thanks Jim. I will give it a try.
motor
'95/Wynn's A/C blower motor repair/replacement tgraham Defender Technical Discussions 12 June 3rd, 2016 03:40 PM
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
A/c blower motor Campbell Defender Technical Discussions 1 September 27th, 2004 08:19 AM
A/C blower motor Campbell Defender Technical Discussions 3 September 9th, 2004 11:01 AM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
