help with 110 suspension setup for expediton / trails - Page 2 - Defender Source
Old April 16th, 2014, 07:16 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
I'd be curious to know why? And I think mounting them in the rear would be easy but not so sure about the front. The gywn Lewis kit recommends +5 shocks and provides mounts for f+r but only for standard shock. Cor4 has the only front remote resevoir shock tower I've seen??
Defender 110
Old April 16th, 2014, 05:30 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Plenty of others. RTE sells them, and I am using Qt mounts.
Semper Fi!
Old April 16th, 2014, 09:12 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Just so you aware Brian (brewie) makes some shock mounts that are pretty sweet. I have a set on my truck and they work just fine. Lots of travel for the shocks and it moves the front ones outside the spring.
Old April 16th, 2014, 11:25 PM
myoverlandrover
josh
109
You reference in your first post you are using QT relocation shock brackets in the front but I can't find them on their site for the life of me.....where are you finding them?
And thanks for the heads up arcadeus
Defender 110
Old April 17th, 2014, 12:00 AM
Wolf Fabrication
Sterling Archer
'08 D3
You reference in your first post you are using QT relocation shock brackets in the front but I can't find them on their site for the life of me.....where are you finding them? And thanks for the heads up arcadeus
Some of it's custom made. Call L8.
Semper Fi!
Old May 3rd, 2014, 09:37 PM
myoverlandrover
josh
109
What did you guys run in the rear to mount a shock with eye's or whatever they are called (not pins) up top? I can only find extended pin style mounts for the frame? RTE has some but claim to be for 90's only
http://www.rte-fab.com/products?page...category_id=56
Defender 110
Old May 4th, 2014, 12:22 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I went with a custom rear set up that brewie made up for me in the old safarigard style... I converted my bottom mounts so I could go eye to eye and get into the more premium varieties (fox, bilsteiin) that tend to be more available in eye to eye styles...
Old May 4th, 2014, 07:28 AM
myoverlandrover
josh
109
That's what I'm after. Cor4 makes an adjustable mount too but I can't get a hold of them. Also worth noting I found out you can convert a fox shock to pin mount on the bottom but not sure with a long travel setup if thst would be pressed to the limit.
Defender 110
Old May 4th, 2014, 11:22 AM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I know someone that runs 14 inch short body bilsteins in the rear with bottom pins. He hasn't snapped any thing yet but I think the eyes have inherently less binding.
Just get brewie to make you up a set and job done.
Old May 4th, 2014, 11:48 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I have a set of new in box 14" SB 7100s I could sell to you cheap Josh
Old May 4th, 2014, 01:04 PM
myoverlandrover
josh
109
Not sure if RTE saw my post but Bill emailed me today saying his will fit a 110 so im going to order those.
Zach, thanks for the offer but after talking with matt I am trying to figure out if I can fit fox 2.5".
Defender 110
Old May 4th, 2014, 01:32 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
If I remember my conversation with bill correctly, those mounts are set up for a 10" fox sizes shock.
Old May 4th, 2014, 02:55 PM
myoverlandrover
josh
109
That's great to know and bill did confirm I can fit fox 2.5" shocks so now need to figure out which ones.
Defender 110
Onboard air setup help needed. RickM Defender Technical Discussions 10 March 9th, 2014 11:12 PM
WTT 1987 90 SW setup for ST setup javelinadave For Sale - Parts 0 July 19th, 2013 12:09 PM
Anyone have experience with this suspension setup bitz Defender Technical Discussions 27 February 3rd, 2013 02:24 PM
F/S Fox Suspension setup pushngo For Sale - Parts 0 February 28th, 2008 10:52 AM
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
