Help...When I press on the brakes, I hear a knocking sound - Defender Source
Old February 16th, 2007, 05:57 PM
WEMICHENER
Bill Michener
1997 Defender 90
I have a 1997 D90, three days ago when I noticed that when I applied the breaks ever so slightly I heard a knocking sound coming from the front end of the car. Just yesterday, when I applied the breaks, it felt like the brake caliber came loose on one side and the whole assembly swang up and made a jerking feel to the pedal so to get home I quit using the brakes and used my emergency break to limp home. When I pulled of the front tires to check the calipers on both sides, everything was ok. I am baffled by the problem I have, I noticed some oil dripping from the front passenger side spherical housing(the round big ball). Anyone have any suggestions what is wrong? CV joint bad?
Old February 17th, 2007, 01:18 PM
WEMICHENER
Bill Michener
1997 Defender 90
Is there no one out there that give me some incite, just a little?
Old February 17th, 2007, 02:21 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Open the swivel ball drain plug. If all the fluid is gone, than you could probably f up the cv joint. Just in case, put the car on jack stands, see if you can recreate the sound with the wheels moving, might be something else. Good luck.
Neil
Old February 17th, 2007, 03:22 PM
How many miles are on the truck? Is it locked? Has it been off-roaded?
Probably is a bad CV. If it is, it is pretty easy to fix.
Old February 17th, 2007, 04:24 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Like suggested by Neil, I'd start with a fluid check. And if there is fluid in there, look for metal pieces coming out also.
You may also consider jacking up one front tire at a time, and spin the tires both ways. In theory, if only one wheel is in the air, it shouldn't spin more than about a quarter turn at most.
If you do have to replace it, it's an easy fix as long as you have the hub wrench and a set of 12pt metric sockets to get the caliper off.
-Hans
My oil line fix
My 100k stopped odometer fix
brake
Low RPM knocking, ideas? OCD90 Defender Technical Discussions 6 September 30th, 2005 05:14 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
Weird sound at idle... OCD90 Defender Technical Discussions 1 November 10th, 2003 02:56 PM
