Help w/ soft top drumming - Defender Source
Old September 21st, 2004, 12:12 PM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
I have a Badger/ RN top that drums like Micky Hart on speed. The worst configuration is when the top is on and the side and rear windows are out. The question I have is what about disturbing the flow of air over the top (Bernoulli)with lamps or a rack? Any first hand experience out there?
Old September 21st, 2004, 12:22 PM
Lamps make a bit of noise themselves. Oddly enough Yousef and I found a way to quiet down the top. When we loaded our stuff on top of his 90 it pushed down on the top and stretched the top a bit, after doing that there was no flapping.
On another note, do you have rollbar pads? The Velcro ones? They help a little.
Old September 21st, 2004, 12:40 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
I gave up driving at speeds over 60 with the side and rear windows out. It got so bad that the drumming pulled out a rivet on the rail system at the rear left corner. The side window seem to be the problem so I put them in when traveling at speeed. The rear window I unzip and clip to the alpine bar to keep it out of the way. In my humble opinion, and not wanting to second guess or insult LR, the top attachment systems, either rail or snap can not handle the wind flow at speed.
The velcro rollbar pads DO help. And on Bernoulli, I believe the principle is that a when airflow is introduced to a disruptive shape (as in a wing) air is divided unequally into two flows. One is above and one below the object. If the flow below is smaller that that above, a pressure displacement occures allowing for lift (or in the reverse down pressure). Looking at the wind screen angle, ridge wher the top meets the front edge, the 3 humps in the top of my soft top to the rear, I venture to state (at my own peril) the aerodynamics of a D-90, at best, suck - literally - , and at worst, were just not engineered into the design.
Final comment. You are pretty close to CA or those warmer states. Ever concidered wintering there?
Old September 21st, 2004, 05:56 PM
Seanh
Sean Hanagan
Mike,
The velcro pads you refer to go where on the truck. I did make some fleece covers for the diagonal roll cage supports to quiet the window flapping. The top you streched, was it a bestop or a canvas top (RN or Badger)? Mine goes right back into a firm shape.
Paul,
If I winter in CA then I cant ski! With regard to bernoulli I was thinking that since the faster the air moved across the top the lower the air pressure relative to the air inside the truck. If I could slow the air down over the top then the top would not be pushed up as much.
Old September 21st, 2004, 08:29 PM
ronward's Avatar
ronward
Redsrover
None - sadly
With the soft top windows in and zipped, open the drivers side door window about 2 inches by sliding the forward glass reward. Works like a charm on my 90.
Old September 22nd, 2004, 08:11 AM
The pads go on the vertical supports of the cage. The top that we stretched was a Bestop.
Old September 22nd, 2004, 07:17 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Sean, We have great skiing here in California. Mammoth Mountain and Lake Tahoe come to mind. Here in So. Cal there are a couple of slopes within a few hours of Los Angeles. Kind of neat... surf in the morning and ski in the afternoon.
Old September 23rd, 2004, 03:00 PM
Seanh
Sean Hanagan
Trade Western 3% powder for Sierra cement? Kidding, the back country skiing in CA is great and so is the cycling. At this point I'm only an hour away from great resort skiing and just a few minutes away from great bc runs. It's been snowing the last two days and I've had all the windown in which makes a huge difference.
Old September 23rd, 2004, 05:22 PM
jstrong98's Avatar
jstrong98
Jon Strong
I second the "open the window" method.
works like a charm for me.
Old September 27th, 2004, 06:44 PM
Seanh
Sean Hanagan
I live at 9000ft above sea level and the air gets quite chilly up here durring our 9 month winter.
soft top
1997 Bestop Soft Top Like New & Misc Parts Adam Armendariz For Sale - Parts 16 December 8th, 2005 01:43 AM
Best Top Soft Top For Sale WCURoverD90 For Sale - Parts 2 November 1st, 2005 04:24 PM
White 95 D90 Soft top for sale.. sniff.. Richard Dekkard For Sale - Vehicles 5 December 1st, 2004 12:38 PM
Original Soft Top 94 D-90 & Surrey Top!!!! doozle For Sale - Parts 7 November 10th, 2004 08:22 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
