Help w/bolt specs- D90 rear seatbelt - Defender Source
Old May 16th, 2013, 12:50 AM
Bradford
Bradford
'94 ST (Arles)
Does anybody know what size/spec bolt runs through the upper seatbelt mount point in the back of a 1994 D90? The bolts on mine were removed when I bought it (as were the rear belts). I have the belts, just need to figure out what size and length bolt goes into that space.
Any help would be greatly appreciated. Thanks.
-Brad
Old May 16th, 2013, 01:30 AM
Not sure on size, but there is also a spacer you need. This is the time when $20 at RN is worth saving the headaches. If you don't want to refit the bolts, it is a normal metric bolt.
Old May 16th, 2013, 07:40 AM
Yup. And that spacer helps ensure you won't poke through the other side of your padded cage with the bolt, which I've seen a few times.
d90, seatbelt
Rear seatbelt Q's Seanh Defender Technical Discussions 5 December 1st, 2005 08:40 AM
Rear seatbelt removal chrisvonc Defender Technical Discussions 2 February 18th, 2005 04:04 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
D90 SW rear wheel carrier mdmccallum Defender Technical Discussions 14 January 27th, 2004 02:45 PM
