HELP!! V8 runs rough when warm - Defender Source
Old July 27th, 2010, 12:12 AM
ember
ember bane
I have a '95 D-90 that seems to run rougher upon warm up, It will buck, sputter, internal backfireing sounds, poping, etc and have no power. I also have to crank a while to get it to initially start. I have replaced the fuel filter, fuel pump, spark plugs, cleaned the grounding points around the coil/amplifier. Any other ideas??
Old July 27th, 2010, 03:12 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Engine temparature sensor in the block.....
reason: when the engine is cold, it give extra fuel. when it warms up the sensor should tell the ECU, which should lean the mixture, but it isn't, so runs rough.
Old July 27th, 2010, 09:53 AM
ember
ember bane
Diesel Jim, thanks so much for the advice. where is the block sensor located?
Old July 27th, 2010, 10:22 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Errrm... can't remember now. there will be 2 sensors, one runs the guage on your dash, the other does the ECU (well, the 3.9 is like this, not sure if it was changed for the 4.0)
The guage one has 1 electrical connection on it, and i think is in the inlet manifold. the ECU one has 2 connections, and i think (from memory... not had a 3.9 for a few years now) is in a steel pipe (in a "T" piece)
Old July 27th, 2010, 02:47 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
The fuel coolant sensor is right next to fuel injector #1. connector looks the same too. its on the driver side in the front.
bill
Bill
v8
start stall no crank, runs like a top rover4x4 Defender Technical Discussions 5 March 7th, 2006 07:59 AM
that warm fuzzy feeling redrover Misc. Chit-Chat 8 February 14th, 2006 12:09 PM
Runs like dog poop Hans Defender Technical Discussions 26 March 3rd, 2005 08:08 PM
Dreaded Emissions Test and P1317- ABS Rough Road d90xj Defender Technical Discussions 3 October 24th, 2004 01:23 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
