Help! Stuck in the Mojave desert w alternator problems - Defender Source
Old November 25th, 2013, 05:19 PM
sro
Sam Odio
2008 LR2
I attempted a crossing of soda lake. Crossing was treacherous - lots of corrosive mud. I went through the lake at high RPMS (3000-40000) to keep my speed up (10-30mph)
Halfway through, the battery light came on. Checking. THE voltage, I'm at 12.2 when running, 12.5 when off. Alternator seems mechanically fine and there is no blown fuse.
Any ideas? Could the corrosive salt mud damaged the alternator?
Old November 25th, 2013, 05:21 PM
Doubt ur alternator failed. Check the connecting wires on the back
------ Follow up post added November 25th, 2013 05:24 PM ------
Ps good luck. Ill bet mud knocked something off.
Mark Kellgren
KM4BOR
Old November 25th, 2013, 05:27 PM
sro
Sam Odio
2008 LR2
Connections are fine. I can read the battery voltage at the alternator when truck is off.
Just sprayed down the alternator with fresh water and it seems to be working now. Going to try to make it to baker.
Could it also be because of heat and it just cooled down while we were inspecting? Not sure.
Action alternator, ~9 months old.
Old November 25th, 2013, 05:42 PM
psykokid
Jake
1997 Disco
So you tried to cross Soda Lake with all the rain and what not that fell in the area in the last week or so?
Get to baker and hit the car wash ASAP.. that is some naaasty stuff you have now covered your truck in. Makes east coast road salt look like water in comparison on the corrosive scale.
Old November 25th, 2013, 07:11 PM
sro
Sam Odio
2008 LR2
Possible, but it seemed fine when inspected while vehicle was on.
We're a few miles out of baker so all seems fine now
I would like to know though since the experience makes me hesitate about going back into the desert.
Old November 25th, 2013, 08:35 PM
I have seen generator brushes stuck from dried mud. All we had was some lemonade to pour on them but it worked. True story.
alternator, problems
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 09:45 AM
Peli 1495cc1 17" Computer Case Desert Tan/Black Maine 110 The Vendors Loft 18 December 8th, 2006 08:29 AM
Team Saluki Desert Challenge 2005 TeamSaluki Trips, Trails and Events 15 November 15th, 2005 01:48 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Desert Rover Rear Long Travel Shock Kit kiphartzell Wanted 0 March 17th, 2005 10:21 AM
