Help: stripped clutch slave cylinder bolt hole - Defender Source
Old September 2nd, 2015, 02:57 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
I have stripped a total of two threads in this entire engine swap... both of which had nothing directly to do with the swap itself.
This time, it was the in reinstalling the slave cylinder on my long LT77 bellhousing. I felt a bit of friction and made sure to hand install the bolt and felt to make sure it was getting threads. Nonetheless, it stripped. Clarification: this is one of the tapped holes on the bellhousing.
I'm prepared to tap a size bigger and also drill out that hole of the slave and metal seal. However, I wanted to check here first to see if anyone had any better ideas. Replacement bell-housing is my last resort. Thanks in advance!
Between 'little things' like this and waiting on small, seemingly inconsequential ancillary parts... it seems that the last 10% of this swap is taking 90% of my time!
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old September 2nd, 2015, 03:01 PM
It would be better to install an insert into the bellhousing so that you can use the stock bolt.
http://www.crosstools.com.au/thread-...t-for-you.html
Old September 2nd, 2015, 03:09 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
yeah, I'd go with a helicoil insert, as John suggests, though it's gotta be a good bite because there are only two bolts and it's all pulling/pushing pressure on the bolt, not any shear pressure.
If you don't think the helical is sufficient, maybe tap it out with a course thread one size up.
Old September 2nd, 2015, 03:15 PM
Based on the mechanics of the slave cylinder I would go one hole size bigger and tap it. If it was a pivot point the helicol would be ok.
Old September 2nd, 2015, 03:39 PM
Helicoils are easy to do and *plenty* strong enough for that application.And much more likely to cause you to cuss in the near or distant future.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 2nd, 2015, 07:18 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you're concerned about the Heli-Coil option (the option I'd use) you can read up on their tensile strength here:
http://www.stanleyengineeredfastenin...C68-2_rev4.pdf
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 2nd, 2015, 07:48 PM
ontheway's Avatar
ontheway
Dave
Welp I couldn't find the coils I needed locally - I ended up tapping one size larger and everything seems to be working out fine. I worried a bit about drilling the thin cast aluminum on the slave but all turned out fine.
Thanks for the help all.
clutch, slave, trip
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
clutch slave cylinder lordhelemt Defender Technical Discussions 4 May 9th, 2013 07:23 AM
clutch slave cylinder. CavemanDiesel Defender Technical Discussions 4 December 27th, 2012 10:39 AM
Clutch slave cylinder new in box for defender jonathon For Sale - Parts 2 December 3rd, 2012 10:42 PM
Clutch Slave cylinder bleed?? Quimbola Defender Technical Discussions 2 February 10th, 2009 11:17 PM
» Defender Registry
Red
KGH
Lola
Add your Defender
