Help - Start of weekend power steering leak - Defender Source
Old January 9th, 2015, 06:18 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Any suggestions would be appreciated. Driving around, notice the steering gets tougher. Figured the fluid was low. Got out and noticed a puddle underneath the steering box. With the weather so nasty outside, I only got a quick glance, but I'd guess its coming from the box, not a hose.
When I refilled the fluid level, there's a steady flow of fluid coming out right at the linkage to the steering.
Any suggestions to limp this along until Monday when I can get it into the shop? Since it's a '94 with multiple belts, the belt to the steering only serves the pump, IIRC. Could I just cut the belt to the steering pump, or would something else go wrong.
"Uhh...I think they all leak like that."
Old January 9th, 2015, 06:45 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Hit it with cleaner and see where the leak starts.
If you are lucky it's a hose fitting - or the pump.
If it is the box it may just be the drop arm seal and a kit (we and everyone else should have them in stock) can renew the seal - much easier to manage with the box on a bench, but doable in situ.
Old January 9th, 2015, 06:51 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
Thanks. It looks to be leaking right around the drop arm. I think maybe the cold snap effected the seal.
Back to my issue, though, is there anything I can do if I need to drive it before it gets fixed?
I don't want to ruin the pump with the fluid level empty.
Old January 9th, 2015, 06:56 PM
Take the belt off and eat your Wheaties is about all you can do if you can't stop the leak. LR o-rings and seals hate cold. Last winter my xfer case pissed itself the first cold night we had.
Old January 9th, 2015, 06:57 PM
SGS714's Avatar
SGS714
Scott Striglos
3xRRC 2xD90 2xD110 Series II, IIA
I've had good luck with Lucas Oil Power Steering Stop Leak as a short term fix.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door VM 2.5TD
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
start
power steering leak tjfslaughter Defender Technical Discussions 4 December 30th, 2013 12:35 AM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
Power Steering Resevoir Leak gas-man Defender Technical Discussions 6 May 1st, 2010 10:32 PM
Power steering reservoir leak - '84 110 cgalpin Defender Technical Discussions 7 December 26th, 2007 06:48 PM
Power steering help D90user Defender Technical Discussions 15 January 31st, 2007 07:10 PM
