HELP!!! Sputtering // Code 44 - Defender Source
Old June 13th, 2008, 04:45 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
So my '94 started sputtering and occasionally dying whilst coming to a stop, and had a real rough idle. I even had some popping coming from the exhaust. I checked the code readout and got a code 44, left O2 sensor. I replaced both and after an initial rough idle everything smoothed out and it idled great and rev'd fine.
Well, I took it for a test drive and after a few minutes it started running real rough - A LOT of popping and backfiring at low speeds and a very rough idle. I almost had to keep my foot on the gas to keep it from dying. It seemed to smooth out at higher RPMs. The worst part - I got a code 44 again!!!
Does anyone have any ideas? I am used to carbs and not these new fangled computer controled engines.
Semper Fi!
Old June 13th, 2008, 05:01 PM
check the wiring for the o2 unit and the terminals of the socket to make sure they are clean
Old June 14th, 2008, 07:32 AM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Carlos Mencia
Dee Da Dee!!!
So it turns out the non-OEM tubing I ran from the MAF to the intake had fallen on the steering shaft and that had worn a massive hole in the tubing. So it looks like I spent $200 on two O2 sensors for nothing. Damn computer told me code 44... I guess I am more angry at myself for not catching that one.
Semper Fi!
Old June 14th, 2008, 06:43 PM
Do you still have the old ones? If so, put them back on and save the new ones until you need them.
Old June 15th, 2008, 05:49 PM
If you truck is a 1994 and they were original, it was time.
Old June 15th, 2008, 08:33 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, they looked pretty crusty. Plus one was stripped and I had to retap the hole. I kept one as a spare just in case. Thankfully AB had the O2 sensors on sale for $99 each, so the damage wasn't too bad.
Semper Fi!
Old June 16th, 2008, 06:22 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
I love this. An 02 sensor code doesn't neccesarily mean the 02 sensor is gone. It means the 02 sensor can't operate within it's limits, probably due to something else....in this case probably lean with an air leak, and couldn't enrich enough to get back in tune. You reset when replacing the sensors and cured nothing.
So don't blame the "damn computer" as in reality it was giving you very good info.
Matt Browne
Old June 16th, 2008, 07:26 AM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks for the valuable witty commentary. My comment on "damn computers" was in reference to my not understanding ECUs and and the vague code 44, as outlined in my previous posts berating myself for being such an idiot. Your rubbing it in makes it all that much better!
Semper Fi!
3.9 stumble stall code 44 rover4x4 Defender Technical Discussions 5 April 4th, 2009 02:39 PM
yet another radio code question GliderKing Defender Technical Discussions 3 June 4th, 2005 05:06 PM
Fault Code 19 chrisvonc Defender Technical Discussions 17 April 29th, 2005 05:28 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
» Defender Registry
Big Red
jec
Rubicon
Sharmin
Add your Defender
