Help! Smoking 300TDI - Page 2 - Defender Source
Old September 6th, 2013, 07:44 PM
leonus1
Frank
1997 Defender 90 SW 300TDI
Can I adjust it myself.
Old September 6th, 2013, 08:01 PM
Very simple with the right tools.
Mark Kellgren
KM4BOR
Old September 6th, 2013, 09:19 PM
leonus1
Frank
Unfortunately all my tools are still in Texas and won't be here until the middle of October. I watched the video and it's great! Thanks again for the help. Any suggestions on where I can get new door panels for my 1997 Defender 90 SW?
Old September 6th, 2013, 09:24 PM
If you haven't worked on your TDI before, it's likely you still don't have the right tools. You need to get a TDI timing kit. You can get them at Rovers North or find a specific kit from multiple providers on ebay.co.uk
http://landroverparts.roversnorth.co...029&type=0&eq=
Mark Kellgren
KM4BOR
Old September 6th, 2013, 09:26 PM
leonus1
Frank
Thanks!
------ Follow up post added September 6th, 2013 08:27 PM ------
Do you think setting the timing will fix both smoking issues?
Old September 6th, 2013, 09:48 PM
Thanks!
We think you need to set your timing regardless of your issues. After that's done, let's see what issues you have remaining and go from there.
Mark Kellgren
KM4BOR
Old September 6th, 2013, 10:06 PM
leonus1
Frank
I will update you once the timing is set.
Thanks Overlander and everyone else for the help.
Old September 13th, 2013, 06:39 PM
leonus1
Frank
Hello Overlander,
I have a question for you. When setting the iP timing, do I need to lockout the flywheel with the pin if I'm not removing the IP or can I use only the timing pin without using the locking pin for the flywheel?
Thanks in advance.
Old September 13th, 2013, 07:04 PM
leonus1
Frank
Cancel the last post, I need the flywheel lockout pin.
Old September 15th, 2013, 08:58 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Has there been any thought to bogging down in fifth? May it also be that the gearing and tire size are part of the issue? For fifth gear at least. I know if I drop the RPM's too much in the higher gearing I will blow more black smoke. Down shift to increase RPM and the smoke goes away. Just thinking....
300tdi, tdi
300TDI smoking on start up graham Defender Technical Discussions 7 February 2nd, 2017 04:50 PM
Defender 300TDI smoking graham Defender Technical Discussions 5 May 24th, 2013 10:02 AM
300TDI new injectors - smoking like mad jaherring Defender Technical Discussions 4 May 2nd, 2011 11:58 AM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
