Help..Replacing door hing bolts - Defender Source
Old March 5th, 2006, 07:54 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
I am getting ready to buy a stainless steel bolt kit for the door hinges for my 94 defender 90 and wanted to know if someone might be able to help me with some technical questions. After looking at the hinges I have questions on how I would get the bolt that attach to the car rather than the door off. Do I have to take off the dash?
Thanks in advance for you help.
Mike Lynch
Old March 5th, 2006, 08:24 PM
All the bolts on the bulkhead can be removed from the outside. They screw into captive nuts (which some call "J-nuts") which are also removeable from the outside once the hinge is out of the way. They are also droppable into the bulkhead cavity and difficult to remove, so I like to tie a little wire to them before I take them out.
Old March 5th, 2006, 08:42 PM
Defender13's Avatar
Defender13
Mike Lynch
Thanks Jim for your help, I really appreciate it. I just wanted to make sure I am clear on what you are saying... If I am able to get the hinge bulkhead screws loose from the outside, I should be able to replace the captive nuts and the bolt from the outside? How does the bolt attach to the bulkhead from the outside?
Thanks again for your time.
Old March 5th, 2006, 11:14 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
Mike the bulkhead bolts screw into a captive nut that is not welded but crimped onto the bulkhead.
The bolt may fight you to come loose, if this is the case you should use an impact driver (not an impact wrench) make sure you use a Pozidrive #4 on the bolts. To remove the other bolts you need to remove the door panel. Unless you want to spend an hour re-aligning each door my very strong recommendation would be to replace one bolt at a time.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old March 6th, 2006, 03:00 PM
Defender13's Avatar
Defender13
Mike Lynch
David and Jim,
Thanks again for your time and advice.
All the best,
ac, bolts, door
starter bolts jstrong98 Defender Technical Discussions 0 November 1st, 2005 11:14 AM
exhaust manifold bolts scoloco Defender Technical Discussions 9 June 1st, 2005 08:57 PM
Head Bolts. Sealant? or no sealant? Hans Defender Technical Discussions 1 January 19th, 2005 11:42 PM
Hub Bolts kellymoe Defender Technical Discussions 9 September 17th, 2004 10:38 PM
Exhaust system bolts rover4x4 Defender Technical Discussions 2 May 7th, 2004 08:26 AM
