Help - Removing the Boge - Defender Source
Old September 21st, 2010, 08:53 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Looking for help on how to remove the bottom connection of the Boge self leveling unit. The shaft goes into the bracket at the bottom and there is no nut to loosen that I can see. The only thing I can see is two flat spots on the shaft itself that I might be able to get a wrench on and just turn the shaft itself. Anyone have experience with this?
Old September 21st, 2010, 09:04 PM
Are you planning on replacing it or leaving it off? If the latter, I just cut the cast mount with a cut off wheel on a 4.5in angle grinder.
Old September 21st, 2010, 09:32 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I am having a hard time picturing your description. The BOGE unit has a ball joint on both ends. There is a collar that holds the ball in place. You can unscrew the ball itself. Here are a few pictures from when I was rebuilding it if it helps:
ID:	31339   Click image for larger version
ID:	31341   Click image for larger version
MUDSUX
Old September 21st, 2010, 11:59 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Planning to remove it but want to avoid cutting it if I can get off without it. MUDSUX, the lower ball joint is what I am talking about according to your description. How does it attach to the lower cast mount? Does the collar thread into the mount or does the ball just sit in there?
Old September 22nd, 2010, 12:12 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
So if I take the top mount loose from the frame, can I rotate the whole unit to unscrew the ball, or do have to remove the whole A-frame as well and then disassemble?
Old May 24th, 2012, 08:51 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Is this thing needed? Or can it just be removed?
Legend in My Own Mind.
Old May 24th, 2012, 09:31 PM
It's useful if you ever carry a load. I believe it pumps up with suspension movement to help take the load off the springs.
Originally Posted by pendy
I'm here for the D's
Old May 24th, 2012, 10:57 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I never put it back on and haven't missed it. I had to cut it off in the end. I have OME medium duty springs and have had 25 bags of concrete in the back before and it was just fine. It might matter more with stock springs though...
vin
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
Removing front shocks Trevor Tarr Defender Technical Discussions 5 April 10th, 2005 04:51 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
removing weather stripping from door bottom JRowe Defender Technical Discussions 4 November 6th, 2003 01:53 PM
