Help removing rear bumper from crossmember - Defender Source
Old October 14th, 2015, 09:10 PM
jperakis
James Perakis
94 ST
How can I remove these bolts from the rear crossmember?
They just turn with the socket so I'm assuming there's a nut on the backside of the crossmember.
This is directly in front of the fuel tank.
Tell me I don't have To drop the fuel tank to get these bolts off!
remember two things...
Old October 14th, 2015, 09:13 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
The "easiest" way is to drop the tank. Several advantages to this...you get to inspect it and apply anti-corrosive chems. Dropping the tank is super easy. Just think it all through and do your "search" research if you've never done it.
Old October 14th, 2015, 09:15 PM
jperakis
James Perakis
94 ST
Old October 14th, 2015, 09:42 PM
You might be able to loosen the tank skid and get your hand back there. I did that with my 97.
Old October 14th, 2015, 09:43 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Did you try backing them out? Some are self retained
bumper, vin
removing rear crossmember bolts-easy? Gkase Defender Technical Discussions 2 July 4th, 2009 03:55 PM
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
fix for rust on rear crossmember/bumper d90_1372 Defender Technical Discussions 2 August 6th, 2004 08:38 AM
