Help removing hose ZZ - Defender Source
Old January 20th, 2014, 11:37 AM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
Think I traced a coolant leak to the hose pictured below. I have a significant leak that starts once the motor is warmed up; a pool of fluid seems to be accumulating right underneath the distributor. And there's an audible hiss. I think this hose is the culprit (behind the distributor, not the large hose on top that leads to the radiator), but being new to Defenders I'd appreciate your help (1) confirming that this is a coolant hose, and (2) any suggestions on removing it ...
------ Follow up post added January 20th, 2014 11:39 AM ------
Old January 20th, 2014, 12:03 PM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
Thanks!!
Old February 1st, 2014, 01:13 PM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
------ Follow up post added February 1st, 2014 01:15 PM ------
Finally found a free moment to tackle this project. Getting the hose off what quite a bit of work, and getting it back on doesn't seem any easier. I coated the inside of the new hose with some dish soap, but there's so little room to work.
I remove the distributor rotor, but can't get the assembly off. I know I'm missing something. If I could get the distributor out of the way, things would be much easier!
Old February 1st, 2014, 01:36 PM
Jas0n's Avatar
Jas0n
Jason
1995 D90 SW #421
I tried heating up the hose with a hair dryer and that's helped get it started. Another inch to go ...
vin
Hose replacements kolvedic Defender Technical Discussions 1 March 14th, 2006 04:50 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
