Help, Positive battery lead fried at starter - Defender Source
Old March 9th, 2011, 03:30 PM
uc4me's Avatar
uc4me
Kevin
1997 D90 Wagon
Hi crew, can anyone help troubleshoot the cause of my positive battery lead that completely fried off the starter termination of my 97 D90 Wagon? I noticed when my battery was drained/dead probably from a short. The truck was sitting a couple wks without running it.
Could it be just a bad starter (switch), a relay, voltage regulator or possibly my ignition switch? Thanks bunchs.
Old March 9th, 2011, 03:36 PM
Bad ground somewhere
Old March 9th, 2011, 06:37 PM
dchapman
Daniel Chapman
1999 D1
Could have just been loose.
Old March 9th, 2011, 07:37 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
The stud on the starter is fried off? The lug on the cable?
Did you find it that way after it had been sitting, or did you try to start it and it fried?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 11th, 2011, 10:43 AM
uc4me's Avatar
uc4me
Kevin
1997 D90 Wagon
Thanks for all the replies! Previously I tried to charge and reinstall what i though was a dead battery and when that didn't work, i tried to jump it which is when i think it fried off possibly from a bad ground as mentioned above.
I still need to troubleshoot where there's a bad ground to engine/frame, heater shield, etc. and yet to see what starter looks like. Might have something to do with my radio crapping out couple months ago and a dome light door switch that only works with you wiggle it. I'll have to revisit in couple wks. Thanks!
Old March 11th, 2011, 10:46 PM
Antichrist's Avatar
Antichrist
Tom Rowe
When electrics get fried it's usually at the point of weakest link.
A bad ground would most likely fry the ground cable somewhere.
My bet is on a loose positive connection at the starter, as suggested above. High current -> loose connection -> heat buildup -> melted connection.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
battery, start, starter
Battery Box Redux chris snell Smaller Projects 31 January 9th, 2016 03:34 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
» Defender Registry
Yamelo
Hank
D110
Add your Defender
