HELP!!! oil pump will not prime - Page 2 - Defender Source
Old February 11th, 2014, 02:11 AM
Landy_Andy's Avatar
Landy_Andy
Andy
Originally Posted by kellymoe View Post
ERR4936 is the one i think I have on there now but not 100% sure. Both fit the same on the block. I'll know for sure soon.
ERR7280 on the left & ERR4936 on the right but flipped over.
If you look at the attached pic the early cam driven pump cover is on the left & later crank on the right. The hole in the casting circled in red isn't fully covered if the later gasket (ERR7280) is used. The earlier type gasket can be with or without a hole, doesn't matter as there is no corresponding hole in the block but the cover hole needs to be sealed. That's why some pattern gaskets don't have that 3rd hole on that side.... prob makes then a bit cheaper as one less cutter on the die punch (eg the one in the Craddocks pic)
Corresponding location (with no hole) on the block circled for reference.
Hope that makes sence
ID:	89476   Click image for larger version
Name:	RV8 block.jpg
Old February 11th, 2014, 07:44 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
ERR7280 on the right
ERR4936 on the left
Email:
Old February 11th, 2014, 11:36 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
This is a gasket I have on hand, will this one work? I know there is no hole on the block so I am guessing this gasket should work?
Old February 11th, 2014, 12:11 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
That gasket should be fine.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Oil Pump Prime??? Nigel Defender Technical Discussions 8 March 28th, 2011 04:23 PM
Oil pump will not prime... greend90SW Defender Technical Discussions 8 April 13th, 2006 08:46 PM
Oil Light Flickering/Oil Pump Glenn_Guinto Defender Technical Discussions 13 October 27th, 2004 08:27 AM
