Help, no reverse light - Defender Source
Old December 18th, 2003, 05:42 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Lightbulb Help, no reverse light
Guys, I need your help on this one...
94 D90 ST, reverse light not working. Checked the fuse, checked for corrosion in the receptacle (none) and replaced the bulb. Still no light... what could it be? Please help!
Thanks!
-Glenn
Old December 18th, 2003, 05:49 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
Help me too. No break lights.
(Since I yanked the pedal box for the master cylinder)
My red rears come on with the headlights but no "breaking juice"?
Old December 18th, 2003, 08:45 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Michael/ Glen:
I had the same problem and the light then went out. Turns out that is was a known issue to LRNA. There is a kit that replaces the bulb sockets, clamp, and has a connector repair kit. Includes new rubber boots and a sealant to prevent the problem in the future. The kit does all five rear lights for 95 on . Kit goes for 145.
Worked for me.
Old December 18th, 2003, 10:10 PM
DId you get that thru your dealer?
Old December 19th, 2003, 02:34 AM
Pull the switch and check to see if it is working manually.
Glenn the socket corrosion issue does not effect 94s
Old December 19th, 2003, 10:27 AM
Glenn_Guinto
Glenn Guinto
Thumbs up Thanks Ron!
Also got your message about the Disco, thanks for the reply.
Okay, so now I know it's not corrosion, not the light bulb, not the fuse and as I just learned, it could be the switch (which is on the tranny). Pardon the ignorance but, is it under the tranny tunnel? Do I access it from the inside of the truck or under? Thanks, you guys are great!
Glenn
Old December 26th, 2003, 02:27 PM
JRowe
Jared Rowe
1994 D90. Stock.
Glenn,
I've got the same problem on my '94 ST. Let me know if you figure out how to fix the problem. Thanks.
Old December 26th, 2003, 04:17 PM
Glenn_Guinto
Glenn Guinto
almost forgot about this one...
I just got a hold of a D90 manual but it's for a 97. I'm assuming this reverse switch is the same for the 94 and/or 97 despite the automatic/manual difference. I'll check it out and will post back!
-Glenn
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Diff-Lock Light Reverse Logic???? MonLand Defender Technical Discussions 5 December 5th, 2006 12:31 PM
Reverse light troubleshooting loykd Defender Technical Discussions 4 August 23rd, 2006 12:56 PM
ZF-4HP22 reverse slipping? kiphartzell Defender Technical Discussions 0 March 20th, 2006 09:30 PM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
» Defender Registry
Betsie
Blinky08
Stinky
lr90na
Add your Defender
