Help, no lights! - Defender Source
Old February 17th, 2012, 04:22 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Help, no lights!
I just turned on my lights. Headlights come on but nothing else. Just put in a new switch a few months ago. No dash lights either???
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old February 17th, 2012, 04:24 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Stock (65W?) bulbs? Fuses all good?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old February 17th, 2012, 06:03 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Thanks for the quick replies guys. I jiggled the switch and it started working. Got it from George at RDS. Think I should call him and bitch about it?
Old February 18th, 2012, 10:42 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
sounds like you are using high wattage bulbs and melted the contacts in the switch , this is why it is necessary to use an upgraded headlamp wiring harness with relays this is one I designed for the Defender
Name:	HD Defender headlamp wiring harness 2.jpg
Chris "V"
Old February 18th, 2012, 12:39 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I know from recent experience this past week that the headlight switch is the weak link in the chain!
Semper Fi!
Old February 18th, 2012, 12:46 PM
Relays for sure...your switches will last a lot longer with them installed.
Use them for the horn, headlights, running lights, hi-beam, aux lights...
Old February 18th, 2012, 12:51 PM
Chris Velardi
Chris Velardi
1975 101FC
To be honest the switch is a fine design as long as it is used only for a trigger . Once you start throwing real headlight current to it the wiring is to and from the switch and the switch itself is grossly inadequate. So the answer is to use it just as a trigger to activate a relay
Chris "V"
Old February 18th, 2012, 07:20 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Funny thing is it was the first time I had to replace the switch since new. It was more of a mechanical issue with it. Got real stiff and finally gave out. Sounds like another problem I have...
ht, lights
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
flickering lights nykx Defender Technical Discussions 1 November 12th, 2004 06:10 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
