Help needed!! Vehicle speed sensor - Page 2 - Defender Source
Old April 7th, 2016, 04:52 PM
Originally Posted by MotoMando View Post
Current Configuration
From Vehicle Bundle - to new connection:
Thin Black - Ground
Yellow/Pink - Black/Red
Black/Red - VDO Pin 8
Thick Black - VDO Pin 3
White/Green - VDO Pin 4
Have you disturbed any of the stock wiring from the VSS to the ECU?
Old April 7th, 2016, 05:17 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
I definitely disturbed the wires. I replaced the 19 year old VSS with a new one. I thought that it was failing. After searching, I found this thread.
Old April 7th, 2016, 05:35 PM
I meant have you changed any of the wiring.
Old April 7th, 2016, 05:44 PM
MotoMando
Armando Centeno
1997 Defender 90 SW
I have not modified the wires off the VSS. My thoughts are the ECU is not getting a signal from the Speedometer that the original speedo use to send. Anyone know how to do that for a 1997 D90?
sensor
Road Speed Sensor Cred Defender Technical Discussions 2 February 16th, 2010 09:37 PM
Speed Sensor for Aftermarket NAV system? 97d90#773 Defender Technical Discussions 2 May 20th, 2006 11:45 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
speed sensor wiring rcork Defender Technical Discussions 2 July 27th, 2004 09:44 PM
Can anybody do a Vin Check for me? Quimbola Misc. Chit-Chat 7 February 18th, 2004 06:24 PM
