Help me put together a Spring/Lift Measurement Database… - Defender Source
Old March 24th, 2008, 09:58 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Exclamation Help me put together a Spring/Lift Measurement Database…
I’m sure many of you are familiar with this ‘lift measurement database’ that Discoweb put together (my old Disco is actually one of the entries on it). I want to try to put together something similar for the Defender. There are pretty decent resources out there for the specifications of OME springs, including listings of current OME Springs on EE’s website, and on ‘jbarge’s’ website, which has specs on some out of production and Land Rover OEM springs.
But what I want to do is put together a database of the measurements from the lower spring seat to the upper spring seat for the different springs when fitted to Defenders. We need someone with a relatively low mileage stock 90 (with springs as close to OEM condition as possible) to get us some baseline numbers as well, and we need everyone to report factors that affect the lift amount, such as winch bumpers, winches (wire or synthetic rope), recovery gear stored in the back, etc. (make and models of bumpers and winches, and weight estimates of gear stored in the back will help people figure out weight differences).
So, I need everyone’s help to go out and park their Defender on a level surface, and measure the distance between the upper and lower spring seats on both the driver's and passenger's sides front and rear locations. Please note if you have staggered height springs (typical to OME sets), and if you are using a trim packer or other spacer (between the spring and seat, not above or below the spring seat), as well as details about your Defender’s equipment level.
I will try to compile the information into a spreadsheet, and see if Chris will be gracious enough to host it the D-90 Source tech section. I’ll start…
’95 D-90, Safari Gard front bumper/skid plate w/ Warn XD-9000i winch, Mantec Sliders, stock rear bumper removed and replaced with Safari Gard Bumper corners, rear of Defender Empty, ľ tank of fuel, Safari Gard Stage III suspension (circa 1998).
~> OME 753 springs in the front. 18.1 DS/ 17.7 PS free, 180 lbs/in (I believe I have to check) 13.25” DS, 13” PS
~> OME 759 springs in the rear. 18.1 DS/ 17.7 PS free, 260-300 lbs/in progressive, 15” DS, 14.75” PS
Also wanted to note that these appear to be the specs for the stock springs, if anyone knows differently, please feel free to set me straight. But we just need measurements to go with them...
~> DS Front, LR code blue/green, 175 lbs/in, 15.19" free
~> PS Front, LR code blue/yellow, 175 lbs/in, 14.80" free
~> DS Rear, LR code blue/red, 225 lbs/in, 15.31" free
~> PS Rear, LR code yellow/white, 225 lbs/in, 14.80" free
~Scott T.
'95 D-90 ST - AA Yellow
Old March 31st, 2008, 09:33 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
No one is interested in helping put this resource together?
~Scott T.
Old March 31st, 2008, 10:57 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I have OME springs with the EE isolators. I will give you a measurement today, I hope.
Old March 31st, 2008, 04:10 PM
Sure, I will help.
Old March 31st, 2008, 07:41 PM
I can measure mine, but not only am I unsure of what they are (I think they are 2" OME) but no idea how old they are, so it seems I'd be a bad data point. Unless you want them all anyway. Oh, and it's on jack stands right now so it might be a while before I can measure
Old March 31st, 2008, 08:26 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Geez Charles, what's taking so long to get yours back on 4 wheels???
Semper Fi!
Old March 31st, 2008, 08:47 PM
Just trying to make sure I don't F up my re-gearing. I'm slow and also short on shop time.
Old March 31st, 2008, 10:59 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
measurements
Front OME 761's with 2 rubberized spring isolators
PS 12"
DS 12"
Rear OME 764's with 1 rubberized spring isolator
PS 14"
DS 14"
Old April 15th, 2008, 11:52 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Well, thanks for taking the time to measure Mike, unfortunately, it looks like this database isn't going to go anywhere...
~Scott T.
Old April 15th, 2008, 01:21 PM
I've got no info to share
hate to put a jeep part on a land rover mattdh Misc. Chit-Chat 20 November 11th, 2005 08:58 PM
Who Has put one Slickrock gas tank skids? revor Misc. Chit-Chat 4 May 22nd, 2005 11:39 AM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
arb switches - where to put scoloco Defender Technical Discussions 8 January 10th, 2005 09:25 PM
HELP!! I can't put my tranny in gear... JRowe Defender Technical Discussions 1 October 12th, 2003 12:07 PM
