Help! LOUD fan noise! - Defender Source
Old August 19th, 2007, 12:20 AM
proulx70's Avatar
proulx70
Paul S.
1997 NAS BRG Soft-Top
I hope this is an easy fix.
About a week ago my engine became really loud; louder than it ever has been. I thought maybe the auxiliary fan was permanently on as it sounds like fan noise. The engine doesnít sound bad at all; just loud! The volume increases with speed; at idle, the engine sounds normal but the sound gets louder as I accelerate. If I hit the kick-down itís it sounds like engine is over-revving but the tachometer is still around 2000rpm. The engine is not overheating.
Itís just a loud blowing noise. Is this the fan clutch? Is it somehow spinning faster than it should?
Iíve heard it make this sound a few times since I got it 3 years ago right after starting it up, but it would go away after a couple minutes.
Any thoughts would be much appreciated.
Thanks!
Paul
Old August 19th, 2007, 08:21 AM
fan clutch
Old August 19th, 2007, 11:30 AM
Probably the fan clutch... Double check to make sure that it is not the water pump starting to go. If it turns out to be the fan clutch, I would change it over to electric fans. Makes a big improvement and you get a small bump in horse power too.
Old August 19th, 2007, 05:33 PM
proulx70's Avatar
proulx70
Paul S.
Thanks folks. I'll get the fan clutch checked out.
Regards,
Paul
Old August 20th, 2007, 09:07 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
IT def. is the clutch. I had the same problem on another vehicle a month ago. IT was noisy and it was really great on fuel economy..err
Legend in My Own Mind.
fan
Overheating fun... Trigger Defender Technical Discussions 10 May 16th, 2005 10:04 PM
now... a loud squealing noise... norros Defender Technical Discussions 2 May 3rd, 2005 09:58 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
