HELP!!! Long term storage - Defender Source
Old March 28th, 2005, 05:04 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Angry HELP!!! Long term storage
Alright, I just found out I am being sent on a special one year project for my company, and I dont think I will be able to take the 90 with me. Does anyone have any advice, checklist or solutions for storage. I think the only time I may see the 90 again is for MAR in October. With the amount of military guys in here, some one has put thier 90 on blocks for a while.
Matt...
Old March 28th, 2005, 05:25 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
You can ship it to me... I'll use it everyday so you don't have to worry about anything gumming up the engine...
Seriously though, if you search google for "storing a car", I'm sure you'll find a whole bunch of stuff. Goodluck.
Glenn
Old March 28th, 2005, 05:49 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I would stick it in a storage unit (The cheap outdoor garage looking ones) with a lock until you get back. Maybe give a key to a good friend so they can get in if necessary or maybe to drive it once in a while. When you get back I'd change all the fluids and anything else that makes sense (maybe belts? I've got no clue).
"It's not a Jeep"
Old March 28th, 2005, 06:03 PM
priest944's Avatar
priest944
Jay H
95 D90 SW
About 3 years ago, I did exactly what Jesse recommended. I got a storage unit big enough for the vehicle, I put one of those tough disc shaped locks on the rolling door, disconnected the battery, and came back 7 months later. Everything was fine, except I had low tire pressure.
I only did this because I didn't have anyone out here to take care of the car or a good place to park it. If I had family around, I would have just parked it, covered it and had someone start it/drive it around the block every few weeks.
Old March 29th, 2005, 11:39 AM
Eric_S
Eric
'97 D-90 ST #1507
I store a car for 6 months every year. Here's what I do:
Change engine oil & filter / If your diff's or trans fluid is old change that too
Disconnect battery
Add gas stabilizer and top off gas tank (to prevent condensation)
That's it. It would be a good idea to get someone to start it every two weeks or so. Let it get good and warm and move back and forth to get the trans and diffs moving. It's better not to start it at all than to start it and not let warm up. If it doesnít get hot enough condensation will form in the exhaust, which is bad.
If you can't start the engine then squirt some Marvel's Mystery oil in each cylinder. Remove the coil wire and crank the engine to lube the cylinder walls. This is supposed to prevent rusting on the cylinder walls.
Hope this helps.
Old March 29th, 2005, 02:33 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Smile
Great ideas, Thanks.
Matt...
Old March 29th, 2005, 03:22 PM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
My Defender 50th Limited edition is in storage for 10 months of the year. Have no problems leaving it. It is in a dehumidified garage and conected to a battery conditioner and thats it.
Best regards
James
Old March 29th, 2005, 05:19 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Wherever you store it, make sure the location is mouse-proof.
Out in the sticks where I am, mice seem to move into the engine compartment of any vehicle left standing more than a few days. 'did some real damage bulding a nest in a carburator once.
Old March 29th, 2005, 07:30 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would not just start the truck, but would actually run it until the exhaust has fully heated up otherwise you will get condensation in the exhaust and muffler and it may rust out. Everything else recommended sounds good. I might put mine on blocks under the frame to help relieve sag on the springs, but I am not sure about that.
Old March 29th, 2005, 07:49 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
Hey Matt - If you store it up near me I'll drive it once a month for you. I'm about 2 hrs from you.
Old March 30th, 2005, 08:50 AM
Eric_S
Eric
'97 D-90 ST #1507
BarryO-
Good point about the mice! They can cause havoc building nests and gnawing electrical wires.
Iíve heard that itís actually better to leave the weight of the car on the suspension. So have the jack stands under the axels not the frame. Anyone know for sure? Iíve never had a problem getting ďflat spotsĒ on the tires, another reason to have the car up on stands. I think the old bias ply tires would get "flat spots" but new radials arenít prone to this problem. Then thereís urban legend about the guy whoís garage caught on fire and his car was on jack stands so he couldnít get out of the garage and he watched it burn.
Placing a bag or two of lump charcoal (not the matchlight briquettes but the real deal) will keep funky odors at bay
Old March 30th, 2005, 10:59 AM
jabber
m j
110
http://autorepair.about.com/od/carcare/a/storecar.htm
http://www.dccarcare.com/tipowk/tipowk15.html
Lots o info just googling around...
Old March 30th, 2005, 01:41 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Phil,
I would need you to take it to MAR for me then so I could fly in hit the trails and fly out again.
Matt...
Long Shot - Trade e320 wagon for D90 uzj100 For Sale - Vehicles 2 November 22nd, 2005 03:07 PM
D90 Storage Boxes chrisvonc For Sale - Parts 8 January 27th, 2005 02:19 PM
Tuffy Storage Boxes ronward Wanted 9 September 29th, 2004 01:33 PM
Lockable Storage in D-90 chach Defender Technical Discussions 16 May 4th, 2004 01:18 PM
How long do your shocks last? nickt Misc. Chit-Chat 10 March 19th, 2004 08:16 PM
