Help locating inertia switch for NAS 94 Defender 90 - Defender Source
Old October 5th, 2016, 12:57 AM
Ken Smith
Ken
1994 NAS Defender 90
Hello,
I'm troubleshooting a fuel pump issue on my 94 Defender 90, and I am at the point where I'd like to reset the inertia switch. I'm having trouble finding information about where the switch is located. Is anyone familiar with where I can find that switch on a 94?
I appreciate any guidance I can get.
Ken
Old October 5th, 2016, 04:54 AM
A search works wonders: http://www.defendersource.com/forum/...tch-26107.html
Old October 5th, 2016, 06:27 AM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Just hold a test lamp on the fuel pump fuse and have someone crank. If the test light "flashes" then the inertia switch is working fine and power is leaving the panel and going to to your pump.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old October 5th, 2016, 08:05 AM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
On my 94, it is with the fuses, little white pop up button sort of in the middle. Pull it up and push it back down. If you have rovergauge, uyou can toggle the fuel pump.
Old October 5th, 2016, 10:38 AM
Ken Smith
Ken
Thank you Jeff for the nice image. I did see that when I was searching earlier. I believe it was already in the down position. As Davis replied, if it is down, I will pull it up and push back down to see if that makes a difference.
I will update with results. - Ken
Old October 5th, 2016, 04:12 PM
My bet is white wire with the black tracer from the coil. But hey what would I know.
90, defender, defender 90, nas, switch
Need help locating an ad Roverlab Misc. Chit-Chat 7 May 21st, 2013 01:00 PM
Defender hazard switch and Inertia Seat Belts triple9music For Sale - Parts 1 December 18th, 2012 11:33 AM
Need Help Locating Part # fleabus Defender Technical Discussions 2 February 2nd, 2008 06:50 PM
94 with AC- how to get to the inertia switch ? Doug Crowther Defender Technical Discussions 3 September 8th, 2006 02:11 PM
What is the Inertia Switch for? Mark M Defender Technical Discussions 9 December 21st, 2004 10:06 AM
