Help!! Let out clutch, POP, no go.... - Defender Source
Old May 3rd, 2012, 09:10 PM
wantone
Rick Thompson
94 ST #1222
94st w/r380 tranny. Been running like a top. 140k miles. Pulled out of neighborhood from a stand still in first, when let out clutch heard a pop, and then no go. No warning signs etc.. Was not rodding it when i let out clutch either. Clutch feels good & when i let it out i head a noise & i depress it noise stops. It is a faint whining/ grinding moise. I took off t cas plate on the underside, no shavings etc. Do you all think the input shaft splines stripped? If so, i guess i have to pull the tranny?.... I did a thread search & thats what i came up with. Gonna take pto cover off next. Thanks guys
Old May 3rd, 2012, 09:31 PM
Does it move with the centre diff locked?
Old May 3rd, 2012, 10:41 PM
wantone
Rick Thompson
94 ST #1222
Yep, pressure from the clutch as usual. Nope. Doesnt move w/ diff locked in hi or low etc. what ia wierd is there was now warning such as knocking, whining etc & i dont drive it real hard & am careful to shift smooth to avoid banging the drivetrain due to all the normal slop in it. Drive shafts r all good
Old May 3rd, 2012, 10:55 PM
wantone
Rick Thompson
94 ST #1222
Any chance ot could be the shift linkage?
Old May 3rd, 2012, 11:32 PM
I think you'll find sadness within the gearbox. Good news if it is indeed that the main shaft let go is that John has rebuilt R380s ready to ship out for about what it would cost you to have the thing repaired. Roughly 1500 on your doorstep.
Ashcroft transmission
Old May 4th, 2012, 09:34 AM
wantone
Rick Thompson
94 ST #1222
wow, about 1500 to the door from the uk and from a reputable source?! looks like thats the route to go if it all is toast, which what i fear.....
what if the splines on the t-case are gone as well? what does it take to fix that?
Old May 4th, 2012, 10:54 AM
Gibraltarjim
James
lightweight 200tdi conversion
I have a couple of rebuilt gearboxes if you can arrange shipping from spain? Only have 2 transfer boxes that are ready to go though.
Old May 4th, 2012, 12:51 PM
Jeff you wish you had an oiler plate that's as bad ass as MY oiler plate. Mine has hypnotic swirly whirly curls....
Old May 4th, 2012, 01:45 PM
wantone
Rick Thompson
94 ST #1222
To drop the gearbox, is it easier to take the t case off first, then the gearbox, of in one whole piece? This will b a one man job.... But i got a shop w/ tools etc
Old May 4th, 2012, 05:48 PM
Dood you just couldn't handle it. Your head would explode.
Old May 4th, 2012, 06:54 PM
wantone
Rick Thompson
94 ST #1222
Ok drop it as one unit. Probably use a cherry picker to just lower it out? Any other tricks or things I need to know to pull it out & put it back in?
Old May 4th, 2012, 07:11 PM
Jeff, I know your type. You'll show yours to anyone who asks.
Old May 5th, 2012, 05:35 PM
wantone
Rick Thompson
94 ST #1222
Good idea on the hi lift tip Jeff, thanks! I put headers on recently so exhaust will b easy. Hope the rest does. When I put it back in, will lining up the input to the clutch require any tool?
Old May 8th, 2012, 12:00 AM
wantone
Rick Thompson
94 ST #1222
Well the splines on the output shaft & t case are stripped.... So i guess it is a call to ashcroft in the morning. I need the gearbox & cross drilled gear forvthe t case. Anything else?
Old May 8th, 2012, 12:16 AM
New clutch, new t-case input seal, new transmission mounts new slave cylinder, new flex line, and hard line and big nut (while you are in there type stuff).
If the transmission is otherwise fine, I would just replace the mainshaft as I am a cheap bastard.
Old May 8th, 2012, 01:28 AM
wantone
Rick Thompson
94 ST #1222
Where can u get the mainshaft? I might give it a shot. Or, should i stick an auto in it?
Old May 8th, 2012, 11:10 AM
I'm not sure if you understand that replacing the mainshaft requires a COMPLETE disassembly of the gearbox...
Old May 8th, 2012, 11:24 AM
wantone
Rick Thompson
94 ST #1222
i understand i studied the pdf of the gearbox overhaul on this forum. is replacing the mainshaft pretty technical to re-place? meaning is it fairly difficult/easy to dissasemble and reassemble for someone fairly mechanically inclined? does it require a lot of special tools and adjustment to set necessary gaps/spacings/tolerances like in a differential?
thanks so much, i am considering giving it a go to re build it my self. i would really hate to have to order one from the uk, send back the core etc., if all i need is a new mainshaft, know what i mean?
Old May 8th, 2012, 12:53 PM
I have redone an R380.
It is not terrible other than the big nut. No worse than any other manual transmission.
An auto would be cheaper than a rebuilt manual (I bet you can get all the parts other than the proper center consol for a few hundred).
Old May 8th, 2012, 12:56 PM
wantone
Rick Thompson
94 ST #1222
i saw you posted about the big nut, that some standard size (what size again?) and impact gun with a rag in the gears works. other than that is it pretty much pressing bearings and gears on and using a gear puller to get them off?
so i need a main shaft and seals assuming bearings are all good.
thanks, i really appreciate the help! i have done pretty much everything on a vehicle except a tranny, so i think i am gonna give it a go
so i need to do some searching for the auto conversion. you use a tranny from a disco I dont you? and dont i need to fab a few mounts for it?
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
