Help - km to miles odometer - Defender Source
Old July 11th, 2014, 07:57 PM
Davis_SouthAfrica's Avatar
Davis_SouthAfrica
Matthew D.
1988 110
Hello!
I was told by the State Patrol during my VIN check that I need to change my odometer from km to miles (not cool) before they can issue me a VIN.
Is this common?
Does anyone know where I can get one?
These will be for a 1985 110 and a 1986 110 - both RHD.
They are not electrical.
Thank you!
Matthew
Old July 11th, 2014, 08:02 PM
Post in the WTB section and hopefully one of the many hoarders here will cough a couple up. If not I think Trevor (Rovah Farm) has them for $200ish each new.
Old July 11th, 2014, 08:26 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
What javelinadave said, check with Trevor at Rovahfarm.
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 11th, 2014, 08:31 PM
Davis_SouthAfrica
Matthew D.
1988 110
Thank you both! I did so just now.
Sweet.
Old July 11th, 2014, 08:50 PM
Originally Posted by Davis_SouthAfrica View Post
Hello!
Is this common?
Thank you!
Matthew
Before they can issue you a "VIN", or a title? I'm really quite surprised by this KM to Miles conversion - are they going to make you swap it to LHD too? Sheesh!
PS - it may be worth asking a second party at the State Police before jumping through the hoops and getting a new odometer.
Several folks on here - myself included - have run speedo's in km without issue. I'm fairly certain that local/state law should not supersede NHTSA, but in reality that coupled with the fact that the vehicle is 25+ years old. I'm sure there are some "true" collector cars out there that would not dare touch the originality of a vehicle such as swapping out a speedo just to satisfy the Super Troopers ("just going over the border for some french fries & gravy, sir").
Old July 11th, 2014, 09:21 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
try EBay UK. I have found them for a good price there. Does your spedo have both KLM ans MPH on the dial?
Old July 11th, 2014, 09:24 PM
In my experience the older km speedo's don't have the miles on them for Rovers...
Old July 11th, 2014, 09:41 PM
http://safarihp.com/prc7373.html
I have several used ones.
Old July 11th, 2014, 09:50 PM
Bet cop cars also have a km markings on the speedo
I'd check with the dmv
Old July 12th, 2014, 05:19 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
The "normal" UK spec speedo's have a smaller KM scale on them as well.
Pure KM ones don't have MPH
Old July 12th, 2014, 10:57 AM
When people used to import motorbikes into the UK from Europe they'd just put stickers on the glass of the speedo to show key mph speeds.
Old July 12th, 2014, 12:35 PM
jafir's Avatar
jafir
Jafir Elkurd
The km speedo that was in my ex-mod showed mph also, but it was pretty new it only had 1000km or so on the odo.
Of course if they are complaining about the odometer the only option is to get a mph speedo.
Old July 12th, 2014, 12:47 PM
Mine came with a KPH only speedo. Both Texas and Arizona titled/registered it with no issues what so ever.
Old July 12th, 2014, 12:50 PM
jafir's Avatar
jafir
Jafir Elkurd
I only swapped mine because I couldn't read the mph at night. Turns out it had a bulb out, and it wasn't just my eyes getting too old to read the little stuff.
Arkansas and Texas didn't care about the km odometer. And since I've got it registered with antique plates that don't expire, they'll probably never see it again.
Old July 28th, 2014, 03:25 PM
Davis_SouthAfrica
Matthew D.
1988 110
Thanks everyone!
Looks like Colorado is a bit different. They are saying I need to switch out to Miles (from KM) and South Africa Speedo's don't have miles anywhere on them.
Also - colorado just passed a law last year saying classic cars are now 32 years old, not 25. Which means I'll have to go through emissions now to register. I'll be selling my trucks nation wide so after I get my VIN and Title I can export out of the state for someone else to register. That's one option. South African drivers seem to take care of their Defenders mechanically so I think they will pass emissions anyhow (second option).
Thanks again for the help. Now I just need to figure out how to switch them out! I can't find any resources online (which is odd).
Old July 28th, 2014, 03:41 PM
Are you asking how to change the speedo? Remove the four screws for the binnacle and pull out. Squeeze the cable connector at the speedo to release. Remove clamps for speedo and pull out. It should all be pretty straightforward.
If it were me....I would spend a bit of money and install a VDO speedo You should be out less than $150 for the speedo and a new speed transducer. A little wiring and you have a speedo that will be 100% accurate, be much easier to see and look a lot better.
Old July 28th, 2014, 03:42 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Geez, absent that, what kind of mental math problems can you entertain yourself with while driving across Nebraska?
Old July 28th, 2014, 03:53 PM
Davis_SouthAfrica
Matthew D.
1988 110
I'll let the next owner worry about that. I'm just switching out the speedo to get a vin and title. I may even put the old km back in b/c it's way cooler and you won't be going faster than the guy next to you.
Old July 28th, 2014, 04:59 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Don't bother swapping out the speedometer. You do not need to do that in order to get a VIN verification (you already have a VIN, what you need to register in CO is a verification of VIN).
I don't know why CSP trooper gave you bad information, but just get your VIN verification at the same location where you get your emissions test. They'll be happy to do that for you (for an extra charge of course) and you'll have that covered.
Or if you don't want to get an emissions test, you can still get the VIN verification done at any emissions test facility.
help with odometer issues anuctoo Defender Technical Discussions 10 April 17th, 2014 08:00 AM
Odometer reads 76% actual miles stevewhitaker Defender Technical Discussions 4 January 21st, 2006 06:07 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
Odometer problem 97 jorge Defender Technical Discussions 3 November 19th, 2003 01:13 AM
Odometer/speedo correct? sherpamike Defender Technical Discussions 2 October 15th, 2003 08:52 AM
