Help Installing WingTop Chequer Plates - Defender Source
Old May 26th, 2010, 02:37 PM
jakethesnake's Avatar
jakethesnake
Jake
95 D-90 ST
I am trying to install wing top chequer plates. I am using the supplied nuts, washers and screws. I cant reach all of the screws from the bottom (underside of wing top- specifically near the headlights on each side)
do any of you have any tips?
thanks
Old May 26th, 2010, 02:58 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
If you can borrow a rivnut tool, you will be better off. Hope that helps. Will be able to take them on and off easily.
Old May 26th, 2010, 03:07 PM
jakethesnake
Jake
95 D-90 ST
Can I still use a rivnut tool if i have already drilled holes in the wing tops the diameter of the screws supplied in the kit?
Old May 26th, 2010, 03:18 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I think I took my headlights out, if I remember correctly. It was a squeeze, but I believe I could reach the fronts from there.
They're pretty easy to remove.
Old May 26th, 2010, 03:43 PM
d90dang's Avatar
d90dang
Matthew
1997 D-90
+1 on removing the headlights
i actually installed mine yesterday
Old May 26th, 2010, 04:26 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
Definitely remove the headlights. Mounted my Mammouth wing top protectors last night. I added the CNC aluminum vent covers but unfortunately the stock screws would not catch on the passenger side. Need to find some longer ones to get it done right.
Navy. It's not just a job, it's a job on a ship.
Old May 26th, 2010, 08:31 PM
If you go the rivnut route you will have to make the holes a bit bigger. That is the route I went.
Old May 26th, 2010, 10:45 PM
gliebig's Avatar
gliebig
Greg Liebig
95 D90
Mine are riveted on.
Old May 26th, 2010, 11:00 PM
Rugbier's Avatar
Rugbier
Gustavo
I riveted all of mine ( 110 and prior 90 )
NO SIGNATURE
Old May 27th, 2010, 05:52 PM
howellm70
Michael Howell
+1 for riveted. It provides a really nice look. I also clear coated mine and used pond liner as rubber buffer in between the plates and the wing tops which makes for a very tight, solid fit.
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old June 6th, 2010, 07:42 PM
Overland90's Avatar
Overland90
95/D90 #169; Aston Martin
I took my passenger side headlight our for the screws...
Old June 6th, 2010, 08:51 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I just reach under the wing from the inside of the engine bay and never had to remove a headlight or anything
Old June 7th, 2010, 08:25 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I used button head ss allen screws, 3/16" diameter and
milled the the "almond" of the 5 bars wherever it was
in the way, to have a flat seating for the screw head.
My advice: paint the hole !
- Charles Eames
chequer plates, wing
Cut to size aluminium chequer plates... JFD Defender Technical Discussions 2 June 3rd, 2006 04:29 PM
Wingtop protectors EnduroPro Defender Technical Discussions 21 March 11th, 2006 10:18 AM
Group Buy: Gas Tank Skid Plates SlickRockFab The Vendors Loft 53 September 20th, 2004 10:13 PM
SlickRock Plates! TwisteD90 Misc. Chit-Chat 6 April 6th, 2004 12:03 PM
ECR kick plates Joe P Misc. Chit-Chat 13 January 12th, 2004 12:50 AM
