Help installing Running Boards D90 NAS - Defender Source
Old May 1st, 2016, 12:22 PM
Tesla1Defender
97 D90 NAS SW
Do not have mounting hardware to install stock D90 NAS running boards.
To install rear portion there are 2 attachment points to outrigger ( I think it's called that).
On the outrigger there is a larger rectangular opening that typical nut with washer is too small.
Is there a certain bracket or backplate needed to install running board to this portion of outrigger?
Pics attached of rectangular opening and also attachment point of running board itself.
Summary: need to figure out how to secure running board to rectangular opening on outrigger.
ID:	148532   Click image for larger version
Old May 1st, 2016, 03:50 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
I'm not able to see my truck right now, but I remember it being pretty self evident how to install these. Mine were used and had no instructions, but they bolted right up. I don't think that rectangular opening was used. They look to be the actual oem units, not after markets/pro-lines, so they should be spot on. Do you have the forward angle bracket? That is the only loose piece of hardware that these things actually use. I would attach the front first, and then see where these things line up in the rear at level/parallel. Should be easier to find the rear bolting location then.
Old May 1st, 2016, 03:58 PM
Tesla1Defender
97 D90 NAS SW
do not have angle bracket for front, will fabricate one. Installed on driver side already and one rear bolt does indeed go through the rectangular opening but as you can see in picture, the size of opening prevents actual mating of running boards to outrigger in this particular location. Correct, not ProLine, OEM.
Old May 2nd, 2016, 08:32 PM
Tesla1Defender
97 D90 NAS SW
bump
Old May 2nd, 2016, 08:50 PM
Tesla1Defender
97 D90 NAS SW
Thank you. I think I am doing forum searches wrong. When I did search and even put AND and + still not coming up. Appreciate the link.
Old May 2nd, 2016, 08:59 PM
Tesla1Defender
97 D90 NAS SW
Hah! My hands do look weird... the camera adds 10 lbs and apparently extra bones and lumps
Old May 2nd, 2016, 09:00 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
No, it's not you the search function here is sooo advanced it's like driving a Top Fuel dragster, it's just hard to handle.
90, d90, nas
Installing running boards fitting question vasily Defender Technical Discussions 5 March 20th, 2015 06:52 PM
Wtb NAS running boards vasily Wanted 4 March 4th, 2015 07:45 PM
NAS D90 SIde Step/Running Boards rwillms For Sale - Parts 0 June 18th, 2012 11:44 AM
Looking for NAS 110 running boards ORover Wanted 0 August 20th, 2009 01:17 PM
Looking for NAS 110 running boards ORover For Sale - Parts 2 August 20th, 2009 01:13 PM
