Help installing choke/hand throttle cable - Defender Source
Old February 6th, 2007, 06:49 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I have a defender choke cable that I am installing as a hand throttle in my SeriesIII. I can route it through the bulkhead right along the existing choke cable and mount it in the dash near my oil pressure guage. My question is how do you mount it? It would seem you have to remove the cable and knob from the housing, drill a hole just a smidge larger than the threaded section, then install the cable housing/locking section from the rear, and lock it to the dash by with the nut and washer. But does the cable come out somehow? Or am I missing something here?
Old February 6th, 2007, 08:54 PM
Andrew Vick
Andrew Vick
95 D90
Looks like to me the knob would come off and that you need a larger washer to the left of the star washer to act as a backing plate. Where these go on a 90, IIRC, is through the thin plastic cowell on the right side of the steering column. Either the knob comes off, or the cable slides off the sheathing.
Old February 6th, 2007, 09:07 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The knob is molded over the end of the cable. I took my column apart and the choke cable is slotted into a metal arm that also holds the ignition tumbler.
Old February 6th, 2007, 09:11 PM
Andrew Vick
Andrew Vick
95 D90
Hmmm. Someone has had to have installed one of these. Did you get it from John?
Old February 6th, 2007, 09:15 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
AB this afternoon.
Old February 6th, 2007, 09:17 PM
Andrew Vick
Andrew Vick
95 D90
So what's on the other end of the cable? Could you slide it out of the sheath?
Old February 6th, 2007, 09:28 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Not unless there is some secret way to do it? The locking mechanism only lets the cable side about 2 inches.
Old February 7th, 2007, 02:30 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
On a '95 Defender the attatchment point in the steering column cowl has a slotted bracket, not a full circle. It is forked I guess you could say. I installed one on mine.
I need to take the time to learn how to post pictures, sorry.
The same way your choke cable is if I understand you correctly.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old February 7th, 2007, 04:32 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It does seem to need a fork to slide into. I rigged one using an old 2.5 ton army truck hand throttle I had. Works but could use a vernier adjustment, my brother just did one a snowmobile groomer that he is going to send me a link too.
This is the one I am going to try. vernier adjustment and you just hit the red button to release.
http://www.awdirect.com/catalog.cfm?...ion&linkid=210
Old February 10th, 2007, 08:17 PM
Captain Spalding's Avatar
Captain Spalding
Captain Spalding
I'm amassing parts for this project now. I have one of these from Aircraft Spruce. It's not a vernier per say, but it has a positive pushbutton lock, unlike the friction type choke knob. The housing is the proper size to fit in the mounting bracket in the steering column with no modifications.
I have already fabbed a clevis, starting out with RC aircraft steel control rod, which is already threaded at one end.
Kevin, did you have to drill a hole through the firewall, or was there an existing one that you used?
Old February 11th, 2007, 09:07 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Cpt. mine fit through beside the speedometer cable. Just in case you're interested, the knob on the LR cable twists to lock at the desired setting. It comes with a clip to attatch it to the throttle. It probably cost more than the one you have though.
Old February 11th, 2007, 10:21 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Mine is a series III bulkhead. it has all sorts of holes. I ended up mounting it on the front of my console between the seats, easy to find and use without looking. I used the large existing hole for the factory seriesIII hand throttle.
Old February 12th, 2007, 10:45 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Follow up, the hand throttle unit from AWDirect worked out perfectly. You can dial the RPMs up and down on the go very precisely and hit the red button to disengage it completely.
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Kickdown cable on ZF, DOH! RedRhinoProducts Defender Technical Discussions 0 November 13th, 2004 10:32 AM
Sub woofer cable? wicks Defender Technical Discussions 17 May 18th, 2004 09:51 PM
Installing new kickdown cable...anyone? P1CR Defender Technical Discussions 4 December 19th, 2003 01:15 PM
