Help> Injector Pump started leaking! - Defender Source
Old May 5th, 2013, 12:28 PM
motorradmark
Mark Hollahan
1985 Land Rover 110 - rhd
Doing some rather routine maint - rear diff fluid change, so no link.
Started it up to check a light, and noticed fluid dripping off the front diff. underneath, saw fuel dripping from bottom of injector pump. Not from any of the pipe unions I could see.
only drips when running. rather good rate of drip, not flowing, just drip, drip drip.
More info: cleaned up the pump. itis leaking from the seam where the injector pipes block joins the main body of the injector.
- is this a DIY level of fix, assuming it is a gasket there.
200 Tdi defender.
Any ideas, suggestions welcome.
thanks
Mark
Motorradmark
85 ROW Rhd Land Rover 110 - 300tdi
04 BMW R1150 GS Adv
Old May 9th, 2013, 11:20 PM
eddyoz
Geoff
1999 TD5 Defender 110
Mark,Yes these injector pumps can be worked on diy within certain limits.I fixed leaks from the throttle shaft O ring and the body gasket on the housing below it for about $27 compared to over $1k quote for a rebuild.All the info was obtained from http://www.aulro.com and http://www.lr4x4.com pretty sure they cover where your is leaking from.
Old May 10th, 2013, 12:34 PM
michael67's Avatar
michael67
Michael White
110 Tdi
I had a similar leak on my 300Tdi. Relatively easy and cheap fix. Most of the parts I bought from a place in San Antonio specializing in VWs. Look for posts by me (michael67) - I'm posting with my phone and there's no easy cut&paste.
Update: post subject is "300 Tdi & dieselgeek.com".
Fox shocks leaking... AggieD90 Defender Technical Discussions 9 March 19th, 2006 01:32 PM
Still can't get my Defender started and getting desperate tmore Defender Technical Discussions 0 May 29th, 2005 11:56 PM
Leaking A/C Ragland Defender Technical Discussions 3 May 24th, 2004 10:40 AM
Leaking... mattwhite Defender Technical Discussions 2 March 29th, 2004 09:53 AM
