Help Identify This Axle - Defender Source
Old May 1st, 2011, 09:03 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
OK everyone, here is the latest challenge from my truck....
My 300 Tdi is an amalgam of 90, D1, and Classic parts. The latest thing I am trying to sort out is the axles.
They are not original... 24 spline integrated drive flange axles, disc brakes all around. Diff has a drain plug at the 4 o'clock position as looking from the rear and a fill plug on the back about halfway up.
So I am guessing they came out of either a Classic or a D1, but I don't know how to tell. I have taken some pictures of the axle end including with the drive shaft removed some. I am hoping someone knows enough about these things to be able to tell me once and for all what they are.
Thanks.......
ID:	38211   Click image for larger version
Old May 1st, 2011, 10:26 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Start by checking the housing to see what number is stamped on it.
Old May 1st, 2011, 10:34 PM
sounds like my d1 rear. RRC rear has different mudshields
Old May 1st, 2011, 10:36 PM
navydevildoc
Neill Thornton
Where on the housing would it be?
Old May 2nd, 2011, 09:45 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Stamped into the long side of the tube, on the "outside" (opposite of the drive shaft). Might need to do some wire brushing to see it.
Tony
1984 110 "Smokey" (sold)
Old May 2nd, 2011, 12:26 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
What are you trying to identify.....the axles or the axle housings.....both? The axle shaft looks to be the standard D1,D90,late RR axle shaft. That being said it means that the spindle(stub axle) and hub are for the ABS varients whether or not you have ABS. If you are saying that the fill plug is on the diff housing then you have an old housing with a 24 spline chunk...maybe I misunderstood?
Old May 2nd, 2011, 06:02 PM
navydevildoc
Neill Thornton
1) There is no number to be found. The PO did a restoration and the axle is painted with something very thick like POR15, hiding any numbers. I am not going to start grinding away paint just for that.
2) I am really just trying to figure out what I have so when I need to order parts I know what to look for... for example if I need new pads, new rotors, etc.... what do I "say I have" to get the right things?
They have to be from something else, since an 84 Tdi did not have disc brakes in the back as far as I know. So the question is from where.
Old May 2nd, 2011, 06:23 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
for the rear, take a picture of the caliper mounting bracket and caliper, also should be a number on the caliper, post those up and should be able to identify by that
Old May 2nd, 2011, 06:34 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
Pads and rotors are the same for D1, D90, and RR Classic. Only difference would be if you had a brake wear sensor which I doubt.
Old May 3rd, 2011, 01:30 AM
TS888's Avatar
TS888
Tony Sims
1984 110
And even if he did there wouldn't be anything to plug it in to on an '84.
Tony
Old May 4th, 2011, 08:22 AM
Scottg
Scott Garner
1992 RRC / 2007 BMW 335i
That has to be from a D1..
My RRC has 24 sp axles and the drive flange is NOT integrated. But they ARE integrated on my girlfriends 98 D1.
HTHs
axle
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
1997 Defender 90 Rear Axle Casing Steve Friedman Wanted 3 March 8th, 2009 07:33 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
