Help identify random bits - Page 2 - Defender Source
Old May 28th, 2011, 05:09 PM
#21: cage bits?
ID:	39178   Click image for larger version
Old May 28th, 2011, 05:14 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
#2, goes in the stock location left of wheel on lower dash where dimmer switch is.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old May 28th, 2011, 05:28 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by rijosho
#20: only found three of these so far.
These are the spacers that go behind yhe spare on a stock tire carrier.
Most of the bags of bolts are stainless replacements for your truck like rear crossmember and hinges.
You also have a few rivenuts in there.
Old May 28th, 2011, 05:35 PM
Resse you picked the easy one.
Thanks Barry. It looks like the PO had started replacing with stainless all around. For the things in baggies I'm just going to do trial and error to figure out which they go to and label accordingly.
The powdercoated things have me the most confused so far.
Old May 28th, 2011, 06:01 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Originally Posted by rijosho View Post
#2: where would these switches go?
Invisible switches are a bitch to locate.
------ Follow up post added May 28th, 2011 11:02 PM ------
#5: Stainless hinge screws I'm thinking
Agree.
Tony
1984 110 "Smokey" (sold)
Old May 28th, 2011, 06:02 PM
Reese_D90's Avatar
Reese_D90
Reese
Resse you picked the easy one. .
I do the same thing with women
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old May 28th, 2011, 06:03 PM
TS888's Avatar
TS888
Tony Sims
1984 110
#6: no idea.
Looks like SS back door hardware.
------ Follow up post added May 28th, 2011 11:04 PM ------
#9: about 10" long.
That's what she said.
------ Follow up post added May 28th, 2011 11:06 PM ------
#15: no idea. Have a bunch of these. Assuming they're supposed to give you threads where you otherwise wouldn't. Do you hammer them into something then you can screw into them?
Rivnuts. Many in the bulkhead.
------ Follow up post added May 28th, 2011 11:07 PM ------
Rear shock upper mount washers.
Tony
Old May 28th, 2011, 06:12 PM
Reese_D90's Avatar
Reese_D90
Reese
#14 looks like a seat belt bolt, maybe to rear bench floor belts.
#16 doesn't go to the truck. That's a wood screw on one end.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old May 28th, 2011, 06:25 PM
Ah good call on the rear door hardware...didn't even think about that.
So Barry says they're tire carrier spacers and you say shock upper mount washers. They look pretty beefy to be washers. I'll see what I have there now.
So that's what rivnuts look like; haven't had to deal with them yet.
I already have the rear bench seat belt bolt in place for the Y belt, so I'll have to double check on #14. Ah #16 random bits!
Old May 28th, 2011, 06:59 PM
bjf's Avatar
bjf
barry f
94 ST #395
Its for the tire carrier. Just had them off and the truck only uses three and guess how many horsey has. Now it could be the same washer as the shocks but I am not sure.
Old May 28th, 2011, 07:28 PM
defeyago's Avatar
defeyago
Santiago
´96 Defender 110 VGTdi SW County
#11: no idea
BTR2371 and BTR2372 Both bulkhead insulation retainers RH y LH (where the switch that turns on and off interior light, when you open any front door, are located)
SANTIAGO
´97 Defender 110 Tdi SW
´04 Freelander Td4 5 dr.
´97 Alfa Romeo 146 TD (Sold)
´95 Volvo 850 GLT Estate
´94 Discovery Tdi (Webasto equipped)
Old May 28th, 2011, 07:34 PM
Wow great eye! So just a replacement for these, huh (pic of my truck)? Nice.
Old May 28th, 2011, 07:35 PM
defeyago's Avatar
defeyago
Santiago
#10: has the little circlip things on the ends.
They look like differential cross shafts to me.
SANTIAGO
Old May 28th, 2011, 07:38 PM
So it looks like this will go here to give a more uniform look.
Old May 28th, 2011, 07:40 PM
defeyago's Avatar
defeyago
Santiago
Right, but you´re gonna have to make the holes for the speaker wires on them. They would be perfect for my truck that doesn´t have speakers on the doors though...
SANTIAGO
Old May 28th, 2011, 08:01 PM
My guess is that's the surround for the hazards and dome light switches, just underneath the steering column?
Old May 29th, 2011, 01:21 AM
14 is a tire carrier bolt. Spendy part.
Old May 29th, 2011, 04:16 AM
ipgregory's Avatar
ipgregory
Ian Gregory
'97 D90 ST #1008
Pins for the side rollers on a Roller Fairlead.
Old May 29th, 2011, 08:57 AM
Good eye, Ron!
Ian I think you're right, too. I was looking at the fairlead yesterday and noticed they looked similar.
Old June 1st, 2011, 02:07 PM
Bump. Still don't know the following:
1.
3.
8.
9.
12. Probably the rear bolts for the bumper to crossmember I'm thinking.
13.
17.
18.
19.
21.
Random non rover question flippedrover Misc. Chit-Chat 21 March 20th, 2006 04:53 PM
Random & Intermittent Fuel? Problem popeohana Defender Technical Discussions 2 July 18th, 2005 02:47 AM
Can someone identify this? Trigger Misc. Chit-Chat 16 March 30th, 2005 07:27 PM
Random Pics Nobrega Misc. Chit-Chat 13 May 13th, 2004 12:07 PM
