Help ID this cracked fuel filler hose - Defender Source
Old April 20th, 2016, 12:48 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
As I was filling the gas tank up this evening, I noticed a small leak coming from one of the many connectors and hoses near the filler neck. The picture shows the small crack in the line - it was only dripping when I was filling the tank.
Can someone help me identify this fuel line? One end of that line disappears into (what appears) to be the top of the fuel tank.
Name:	cracked gas line.jpg
Thanks!
Old April 20th, 2016, 02:16 AM
Omero's Avatar
Omero
Omar Alomar
2000 D110 CSW 6.2 LS (was TD5)
Yes. This is a vent hose connecting between the filler neck and the top of the tank.
Old April 20th, 2016, 02:28 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Agreed. As a quick fix (that could last forever) grab some vulcanized rubber tape, start wrapping the pipe below the beginning of the crack, and work your way up to the worm gear hose clamp. Then loosen the clamp and keep taping all the way up to the end of the pipe. Then re-clamp everything over the tape. A year or two from now, try to remember that the pipe still needs to be replaced! ;-)
Old April 20th, 2016, 03:12 AM
lithium1330
'97 SW NAS 4.6
Thanks, Omar & David.
I hadn't thought of using the vulcanize rubber tape - awesome suggestion!
That difficult job just got a lot easier! Thanks!
ac, fuel, rack
Fuel filler Hose...Big $$,Any Options isleofbones Defender Technical Discussions 7 May 11th, 2011 08:28 PM
Source for fuel filler hose D90user Defender Technical Discussions 24 October 22nd, 2009 04:12 PM
WTB Fuel Filler Hose 97 D-90 wadaman Wanted 0 January 6th, 2009 08:32 PM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
fuel filler hose mattdh Defender Technical Discussions 2 October 31st, 2003 08:17 PM
