HELP, HELP Dead D90 in CT - Defender Source
Old June 26th, 2005, 08:22 PM
januconn92's Avatar
januconn92
Jan Jurgielewicz
97 D90 #1477 Green ST
Hello All,
Well I rove my 90 home, then went to restart it. Turn the key and the engine / starter will not crank, I have full power, good battery (even tried jumping it). Seems the starter does not want to kick? Is there an easy way to test? any other ideas as to why it won't crank?
The worst part is that I can not get the truck (97, auto) into neutral to move it, whether I turn the ignition, step on the break, etc.. It is blocking my garage and my new car is now blocked !!!
If anyone has any ideas, especially how to get the truck into neutral, I would really appreciate it.
Dead D90 in CT (Jan)
203-650-0924
Old June 26th, 2005, 09:18 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Try the ignition relay. In the fuse box. one on far right. Take one of your relays of and put it in the far right relay position and try cranking it again. I'd lay 10 to 1 thats it.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old June 26th, 2005, 09:57 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You say you can't get it into neutral? Sounds like your starter might be jammed into the flywheel possibly, happens from time to time when they get older. Take something heavy, bonk the side of the starter a few times, then try again.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 26th, 2005, 09:58 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
hit the starter with a soft hammer while turning the ignition...the coals may be a wee bit resisting the turns...
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old June 26th, 2005, 10:31 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
ignition switch? Is that a problem on 97s too?
Old June 27th, 2005, 07:44 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
still dead but more info found
Hello all,
Well after reading a thread here, someone had the same issue not getting it out of park due to a dead fuse, the fuse for the brake lights, sure enough the fuse is dead BUT when I change it, the new one pops as soon as I try the ignition...any ideas on what can be popping the fuse or how to bypass so I can get the truck in neutral??
Jan
Old June 27th, 2005, 08:25 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Originally Posted by januconn92
Hello all,
Jan
Jan, maybe the brake switch is causing the fuse to blow, just a thought.
John C.
Old June 27th, 2005, 09:17 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
anyone know where to find the breaklight switch?, what does it look like?
Old June 27th, 2005, 09:26 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I know this may be an idiot statement, but to try and get it to get in neutral have you used a giant fuse (like larger amp), so it won't blow?
"It's not a Jeep"
Old June 27th, 2005, 09:40 AM
http://www.defendersource.com/forum/...ead.php?t=4638
Old June 27th, 2005, 10:12 AM
JohnC
Switch is by the brake pedal. I'm not sure on a D90 but on a RR/DI there are two switches, one for the cruise control and one for the brake. BTW, are your brake lights working?
John C.
Old June 27th, 2005, 10:58 AM
Hans's Avatar
Hans
Hans Haase
Hmmmm, sounds like an electrical short somewhere.
-Hans
My oil line fix
Old June 27th, 2005, 11:17 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
thanks to everyone, I had to disconnect the shift linkage to get it onto neutral, then the truck rolled. I think there is a short as fuse #17 keeps blowing, time for AAA to tow it to the shop.....
thanks again for all the advice.
Old July 3rd, 2005, 01:22 AM
I'm in the boat as you Jan. AAA took it to the dealer this afternoon. Nobody will be working till the 5th. I'm just glad that this did not happen on some remote off road adventure. Pulling the cotter pin and disconnecting the shifter is the only way to get into neutral. I'll let you know what they find.........
Old July 3rd, 2005, 10:45 PM
gear box electrics. take a few bong rips you will figure it out good luck
Old July 5th, 2005, 11:11 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
still no word on my truck
yeah, my truck (when I talked to the shop last week) has a short, they can't find it so they need to rip the dash out, basically this one is going to cost me $$$.....
I'll let you all know what they find...
BTW, nice pic with the left handed strat and gorilla
Old July 8th, 2005, 08:20 PM
Got mine back today. The positive battery cable was not making a good connection. They retightened everything and the 'beast" sprung back to life.................. Go figure.......
90, d90
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
94' D90 ST, 55k miles LOWERED to 21.7k or BEST OFFER in CT. PIX link januconn92 For Sale - Vehicles 1 March 15th, 2004 09:46 PM
94' D90 ST, 55k miles, 23.5k or Best Offer in CT. januconn92 For Sale - Vehicles 0 February 22nd, 2004 04:16 PM
