Help 'Faking' Spot Welds - Defender Source
Old March 16th, 2009, 10:32 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
Hello:
I'm in the process of replacing the driver side rear body panel on my 'project' D90 and am wondering how to duplicate the factory spot weld marks. I've searched the threads and seen several ideas from using 'flush head' rivets to drilling holes and using filler to create the effect. I've even had a local body guy say he fakes spot welds by using the eraser on a pencil to make a mark in the primer when damp and then painting over it. Seemed like a good idea except for the need to have the correct lines of evenly-spaced 'welds' on the panel.
Any thoughts on this would be greatly appreciated. I could have my body guy rivet the panel on (along with adhesive) but do not know where to source the correct flush head rivets and how then to finish them correctly.
If anyone has any photo references or can suggest another possible route that would be great.
Cheers,
CARL
Old March 17th, 2009, 12:42 AM
pendy's Avatar
pendy
jim pendleton
89'd90
If you use a high strength two part metal body glue to fasten the pieces. Clean metal to bare where you glue. Let the glue ooze through the old spot weld holes. When it dries to a certain hardness cut the oozed bit flush with a sharp razor blade. As the glue continues to dry it will shrink back a bit more and look exactly like a spot weld hole. These type repairs can be stronger then stock if done correctly.
Find a way to practice on some scrap material.
JP
legend in my own mind
Old March 17th, 2009, 07:28 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
And to get the location of the original holes, just make a template on a piece of thin paper to transfer to the new panel
Legend in My Own Mind.
Old March 17th, 2009, 09:05 PM
Green Blood
Carl Phillips
Had thought of doing that and it would work well if I am going to drill or rivet. A bit less easy to transfer-over to the new part if I do the trick I mentioned with the pencil eraser in the primer.
Still wondering if flush rivets could net me a similar result (if I knew where to find them.)
Thanks for the ideas.
Cheers,
CARL
spot the waterfall jimmy salmon Misc. Chit-Chat 19 November 22nd, 2013 12:18 PM
Engine sweet spot and highway RPMs cgalpin Defender Technical Discussions 32 December 30th, 2009 12:02 PM
watch your blind spot Caribsurf Misc. Chit-Chat 14 August 31st, 2006 07:02 AM
Spot the Bellybutton! jimmy salmon Misc. Chit-Chat 24 March 23rd, 2005 07:06 PM
Spot Lights Glare OilSpill_1 Defender Technical Discussions 5 August 28th, 2004 11:09 AM
