Help...E-brake drum screw - Defender Source
Old May 31st, 2015, 10:21 AM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Was swapping out my rear drive shaft, when I notice I am missing the screw that goes into the brake drum where the rear drive shaft bolts on.
Anyone knows the size of screw to replace it?
Is it a special order one?
Any help would be great,
David
Old May 31st, 2015, 10:22 AM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
The diagram
Old May 31st, 2015, 10:44 AM
Most likely M8.
Old May 31st, 2015, 11:40 AM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Thanks, it's a m8. But, I'm trying to figure out the length.
Old May 31st, 2015, 11:54 AM
Honestly you don't really need that screw...its only real purpose is to keep the drum seated in place before the driveshaft is connected.
Old May 31st, 2015, 11:58 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Exactly-- helps to hold the drum on when driving around shaftless...
Rent my
Old May 31st, 2015, 12:04 PM
you could also just put the nuts back on if shaftless...not sure I'd trust just that small set screw anyhow!
Old May 31st, 2015, 12:16 PM
Does not matter much.
Old May 31st, 2015, 12:33 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
True...the set screw is good for 'round the block test drives...probably not for much longer!
Rent my
Old May 31st, 2015, 12:46 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Brake bleed screw size leastonce Defender Technical Discussions 0 December 8th, 2014 06:04 PM
Blew u-joint in rear, help on 4 bolts removal on brake drum UpnOver Defender Technical Discussions 3 February 2nd, 2012 07:53 PM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
110 drum brake shoes FS ECR For Sale - Parts 5 July 23rd, 2006 09:03 AM
D-90 rear drum brake axle assembly TDI Guy For Sale - Parts 0 November 6th, 2003 04:59 PM
