HELP! Does a 95 3.9 D90 NAS have a Crank Position Sensor - Defender Source
Old June 19th, 2010, 04:13 PM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Still no spark, isn't throwing a code since i disconnected the battery. There is spark from the coil to the distributor but not from there to the plugs... In dire need of getting this moving again. Thanks for the help
Old June 19th, 2010, 06:29 PM
I don't think so. If you have spark to the coil, then I'd say your ignition module/amplifier is bad. Search the forums for a bunch of posts on them, as well as an expensive relocation kit that is recommended.
Check the cap and rotor but this doesn't sound like it's the problem.
hth
charles
Old June 19th, 2010, 08:58 PM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Thanks for the response, i've spent a good portion of the day cruising the forum while racking my brain as to why i can't get it started. Cap was replaced today, coil is really new. Downside of being in Southern Georgia is a lack of places to readily get parts from. Order is being placed for the amplifier and rotor... hope this helps.
Old June 19th, 2010, 09:32 PM
have you checked the fuel pressure maybe Im a little late on this post, I hope I am.
Old June 20th, 2010, 08:21 AM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
fuel pressure seems to be good on it, ordering the ignition amplifier module and a new rotor today.. hopefully this solves it
Old June 20th, 2010, 08:38 AM
671rover
671rover
94 d90
I had similar problem with my 94 before and it turned out to be a bad rotor.
Old June 20th, 2010, 04:24 PM
Coug D90's Avatar
Coug D90
Tristan Felchlin
1995/D90
Who knows what it was but through a combination of new rotor, cap, wires and cleaning all the contact points we have success! Now just to replace the headers and the 02 sensors and we are good to go.
90, 95, d90, nas, sensor
TPS - Throttle Position Sensor for 1997 D90 #ERR4278 pcscharfe For Sale - Parts 11 August 27th, 2009 02:31 PM
'95 NAS D90: Ready for the Rubicon or rush hour... KG6BGJ For Sale - Vehicles 0 September 17th, 2005 08:23 PM
95 D90 Station Wagon Doors White. Richard Dekkard For Sale - Parts 4 April 17th, 2005 05:15 PM
Need 95 D90 Stock Front bumper Vadim Wanted 1 July 7th, 2004 12:04 PM
'95 Yellow D90 ST w/ 3 tops dalesmith71 For Sale - Vehicles 10 March 19th, 2004 09:59 AM
