Help Diagnosing a winch problem... - Defender Source
Old April 27th, 2010, 04:19 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
So among the carnage that occured over the weekend was the apparent death of my winch... the motor seems to still work as it will run in reverse (letting line out) but just gives an audible "click" and then nothing when I try to get it to pull line...
This is (was?) a Superwinch x9 - does anyone have a clue what I might check before I designate this as a really heavy paperweight? I hate to have to just replace it (especially given everything else I broke and will need to be replacing)
Old April 27th, 2010, 04:47 PM
I am sure it's repairable. Certainly far less than to replace it even if you used a dealer.
Maybe a solenoid is bad? OR do you hear the motor trying to work but can't move?
I'm not sure what that has for solenoids, but if it has two, you could try swapping them as a test. If it no longer sppols out but will spool in then you just need a solenoid.
Old April 27th, 2010, 05:00 PM
Hot wire it with jumper cables and see if it engages pulling in. If so, bad solinoid. If not, you have to consider the motor or gears as having a possible issue.
Old April 27th, 2010, 11:42 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Brad.
I have a X9 Superwinch with the same issue but in the opposite direction. It's one of the Solenoids that needs to be replaced. A $25 part. Mine will pull in just fine but won't let out, I have to pull it by hand. Download the manual here: http://www.superwinch.com/UserFiles/File/90_17371.pdf The solenoids are on page 19. The part number for the solenoid is SPW-2237 and you can order it here: http://www.summitracing.com/parts/SPW-2237 I have mine, just haven't installed it yet.
Old April 28th, 2010, 12:17 AM
bharris's Avatar
bharris
Brad Harris
Originally Posted by Manimal View Post
Brad.
excellent... thank you
I may try to switch them first to make sure that's the problem... of course it would have been nice if the OTHER one had blown and I could have still pulled...
Old April 28th, 2010, 11:05 AM
I carry spares with me.
Old April 28th, 2010, 12:12 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If you want to be able to trust it a bit more replace the solenoids with some of the solid state switches available like the Albright units or a newer Superwinch control box which I believe use solid state sealed units.
Old April 28th, 2010, 04:31 PM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
I had a same problem with mine. The solenoid wasn't bad. The contacts were corroded and were not making good contact. A wire brush and dielectric grase got it going again.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old April 28th, 2010, 05:19 PM
Change to an Albright if you are spending money...
http://www.expeditionexchange.com/ca...cat=300&page=1
winch
Warn Winch Problem TDI Guy Defender Technical Discussions 6 March 31st, 2010 08:42 PM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
