Help: Defender 200 TDI Belt Replacements - Defender Source
Old October 2nd, 2015, 10:40 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
I'm stuck. Had some belts break on a trip tonight. Lost the tach, then power steering, then looked at the dash and temp had just hit the front tick mark in the red (not sure how long it was there). short time later green rain is hitting windshield. Pulled over and both the drive belt and alternator belts are gone. PS belt still there but probably slipping. Not sure where the coolant is coming from yet- hope I didn't F-up the water pump. Engine starts and runs fine (just checked it). Need to get this back on the road tomorrow.
Does anyone know of NAPA (or equivalent) replacement belt #s until I can order genuines on Monday?
Thanks!
Old October 2nd, 2015, 10:47 PM
See here: http://www.defendersource.com/forum/...ght-63502.html
There is zero need to get a "genuine" belt. One belt is as good as the next.
You need to find the cause of the failure. Check that the alternator and water pump spin free. Buy two sets of belts.
The PS belt probably slipped from get covered in coolant, so just make sure it is tight.
Obviously top up the coolant and get extra.
Hopefully you did not kill the head. They do not take well to overheating.
Old October 4th, 2015, 04:32 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
Thanks John- appreciate it.
Well turned out not t o be the belts- at least, not the original cause of failure. Looks like a hole in the bottom of the rad leaked coolant on the drive belt, causing crank pulley to spin and burn the belt up; probably overheated and caused the rupture you see in the pic, spewing coolant on the PS belt- at least that's what I think happened. Spent yesterday removing everything in preparation for a new rad I'll be ordering tomorrow from RN. Hoping all this work doesn't lead me to find cracked/ leaking head.
ID:	131530   Click image for larger version
ac, defender, tdi
Used Proline 200 TDI Radiator & 200 tdi intercooler mgreenspan For Sale - Parts 4 April 8th, 2014 03:38 PM
OEM Antenna or Replacements boshea Defender Technical Discussions 14 January 18th, 2006 01:15 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
Exact replacements for OEM speakers Kimos Defender Technical Discussions 6 December 21st, 2004 12:46 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
