Help, brake light problem! - Defender Source
Old July 6th, 2005, 07:00 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Unhappy Help, brake light problem!
Well, I do not have any brake lights when I press on the brake pedal. When I turn on the headlights, the rear brake lights come on, but do not increase in intensity when the brake pedal is pushed. All the fuses look O.K., and the little servo on the top of the brake master cylinder are looks o.k too. Where should I start looking for problems?
Matt...
Old July 6th, 2005, 07:42 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Rear wiring harness on the frame. Check for loose grounds. . .
Old July 6th, 2005, 08:38 PM
Jase
Jase
pending
Check for corrosion/rust in the pigtails.
Old July 7th, 2005, 12:53 AM
Mark M
Mark Mathews
'94 Beluga Black ST
When I had a similar problem the dead part was the brake light switch. The tail lights worked, but the brake lights didn't. The replacment part number is PRC4297 (page 298 of the parts manual). It's around $19 at a dealer. The problem is installing it. It is above the brake pedal assembly on the engine side of the bulkhead. After trying to do it myself and realizing that replacing it involved removing the whole brake pedal assembly I paid a local independent Rover shop to do it for me. No mess, no fuss, no pissed-off landlord. If you have the tools, confidence, and workspace it is a cheap do-it-yourself repair.
Old July 11th, 2005, 02:32 PM
Dfndr90's Avatar
Dfndr90
Matt Wunderle
1995 Defender 90
Thanks Mark,
I replaced the switch and my brake lights work again. Easiest 21 dollars spent so far.
Matt...
Old July 11th, 2005, 07:39 PM
Mark M
Mark Mathews
'94 Beluga Black ST
Glad to help.
Happy rovering!
-Mark
brake, ht
Weird brake light issue on my 97 Please HELP! Cyborg Defender Technical Discussions 8 July 12th, 2009 01:04 PM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
Tailgate, Tire Carrier, 3rd Brake light, rear bumper jabber For Sale - Parts 5 December 8th, 2005 02:10 AM
tire carrier, 3rd brake light, and other stuff jabber For Sale - Parts 12 January 20th, 2005 03:06 PM
