Help blew my transfer seal - Defender Source
Old September 25th, 2006, 09:57 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Help blew my transfer seal heading up to do some wheeling at the Fall Heritage event in VT this week end. I was driving and started smelling a terrible smell . I pulled over and discovered that gear oil was dripping from the Ebrake drum
I need to replace the seal that goes behind the Ebrake drum.
i have the Ebrake drum off now and im not sure where the seal is. does the whole assembly have to come off?
I unbolted it and hit it with a rubber hammer but it didnt move . does something else need to be unbolted?
Any help would be appreciated. I have attached a picture to show you where i am in the disassembly.
Old September 25th, 2006, 12:40 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Ron,
Email me and I will send you a pdf manual for the lt230. I just tried to attach to this post and it is 1.4m and its limited to 1m.
Old September 25th, 2006, 12:43 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
Originally Posted by Baldewin
Ron,
Check out the attached pdf on the lt230. I haven't done any work on mine yet but have looked into it.
where is that pdf attached? i like to get a look at it as i'm about to embark on this repair myself.
Old September 25th, 2006, 01:19 PM
redrover
Guest
Posts: n/a
Ron you are looking right at it in the pic. The black outer ring is the seal. Just pry it out and install a new one. Pre grease the new seal and carefully tap it back in. You will also need a new brake pad kit. JP
Old September 25th, 2006, 01:28 PM
ron's Avatar
ron
Ron
Chris, email sent...
JP thought so but wasnt sure.
yep the shoes where soaked i sprayed them with some brake cleaner the seem ok.. its a shame the only have 3,000 miles on them
The speedo isnt working is that a gear inside the case i can slide out and replace ? where can I get one?
Old September 25th, 2006, 03:10 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
You should also look at the condition of the collar on the drive shaft. If its smooth with a slight ring mark it may be ok but if it has a deep groove into it, that might be causing some of your problems. If its not too bad you can sand it smooth. I pried mine out with a flathead screwdriver and a hammer than drifted in a new one with a piece of wood and that hammer.
Neil
Old September 25th, 2006, 03:27 PM
ron's Avatar
ron
Ron
I'll look at it tonight
Old September 25th, 2006, 10:35 PM
redrover
Guest
Posts: n/a
Ron I doubt there is anything wrong with the bearing. I would replace the seal. torque the flange bolt to the right spec, and get back on the road. Also the drum shoes are like sponges. I doubt you will get them to work like new shoes. it is to bad they cost so much. JP
Old September 25th, 2006, 10:59 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
You can always get the shoes relined with new material for real cheap at some brake shop. I do it with the hand brake cause it is not realy a performance item. But I agree you do have to change it.
My 0.02
Pat
Kirk Lazarus, Tropic Thunder
Old September 26th, 2006, 09:12 AM
ron's Avatar
ron
Ron
Hopefully the bearings are ok. but my speedo stopped working when I lost the fluid. does the speedo gear just slide out?
I will most likely get new shoes. there is a local guy that used to do my studebaker shoes for me. i hope he is still in business.
Old September 28th, 2006, 02:15 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
can somebody email the transfercase pdf, i was hoping to pull the thing apart this weekend and having some instruction would really help!
Old September 28th, 2006, 03:31 PM
ron's Avatar
ron
Ron
whats your email address and ill forward
Got the seal in and no leaks. Transfer case sounds good and shifts good.
But
The speedo isnt working. Is that a gear inside the case i can slide out and replace ?
i took the speed sensor off and the collar around the femalel portion of the speed out put .
Does this just slide out or is there something Im missing?
is this where people change the gear to make the speed read correctly after going with the bigger tires?
thanks all for the help.
If the seal holds up and I can get my buddies truck running Ill be towing the D down to MAR for some off roading.
Old September 28th, 2006, 03:53 PM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
Ron jack a wheel up and get someone to spin it while you look at the gear to see if its turning. It could be somthing else at fault
3rd low and BOOT IT
Old September 28th, 2006, 09:15 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
But
tkavanaughATgmailDOTcom
Thanks!
Old September 29th, 2006, 07:40 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Ron, can you email me the doc as well? My rear seal happens to be leaking as well.
Dave
Old September 29th, 2006, 08:24 AM
Retrofit's Avatar
Retrofit
Pat
Dave
Hey I'll take it too if anyone cares to forward it to me.
Always good to have the right documentation do the job .
Pat
Old September 29th, 2006, 09:02 AM
ron's Avatar
ron
Ron
Angry
daves whats your email address I dont seem to have it
sent to Trevor and Pat
speedo still not working
Old September 29th, 2006, 09:27 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Sent you an email.
Old September 29th, 2006, 09:59 AM
Retrofit's Avatar
Retrofit
Pat
oups !
retrofit@videotron.ca
Pat
Old September 29th, 2006, 03:28 PM
ron's Avatar
ron
Ron
on its way
Transfer Case Overfill D90user Defender Technical Discussions 19 May 10th, 2005 01:51 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Rebuilt LT230 Transfer case Bill Jansz For Sale - Parts 0 March 9th, 2004 07:00 AM
transfer case redrover Defender Technical Discussions 9 January 27th, 2004 02:41 PM
looking for a Transfer Case for '94 D90 rover_rich_d90 Wanted 5 November 12th, 2003 06:46 PM
» Defender Registry
old blue
Akrovers
1304
xjahx
Add your Defender
