HELP! Big end bore spec - Defender Source
Old March 5th, 2010, 01:27 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have my connecting rods at the machine shop getting inspected and they need to know the big end bore (4.6l) but I don't have my manual--can someone let me know if they have theirs handy?
Old March 5th, 2010, 02:01 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
RAVE says
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 5th, 2010, 02:06 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That gives us the crankshaft journal diameter, but they are checking my rods and resizing the big ends--can't find the spec for that anywhere! Help if you know it. THanks!
Old March 5th, 2010, 02:22 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Oh, sorry. I don't see oversize OD bearings in Microcat, so don't know what to tell you.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 5th, 2010, 02:53 PM
journal diameter + (recommended clearance x 2)+(bearing shell thickness x 2)?. I've had big ends reground where the caps got mixed up. Didn't ask for any figures I guess they just took off as little as possible. Plastigaged everything on re assembly and we were fine. i know that is not the answer you are looking for, sorry.
Old March 5th, 2010, 03:06 PM
Antichrist's Avatar
Antichrist
Tom Rowe
For some engines you can get oversize OD bearings, like my Perkins, but I've never seen any for Rover V8's. Then again I've never looked really hard either. The factory engine manual doesn't even mention checking rod big end dimensions.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 5th, 2010, 03:44 PM
Don't allow them to do anything but mike the rod ends for roundness. I don't think there's anything else that can be done to them. If they are out of round they should be replaced.
Old March 5th, 2010, 06:43 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
2.315" in case someone needs it. And yes, there are procedures for correcting rods--it happens all the time that they get trued up. Just couldn't find the value anywhere.
Old March 6th, 2010, 10:20 AM
I think what they do is mill a bit off the mating surface of the rod cap. Then they can rebore the interior to the correct size. Same can be done with main bearing bores
Old March 6th, 2010, 12:20 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Yep--that is correct. Thing is, this number is not printed in any RAVE or any of the engine rebuild manuals. One would think it might be handy to have printed there but...
Old August 24th, 2015, 05:42 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Did this turn out to really be the right dimension? Where did you get the figure?
Someone on another forum was looking for the same data for the 4.6 and was told 2.187-2.189" (by Rover Cannibal) and I found a site that said 2.185".
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
front end moves jimmy salmon Defender Technical Discussions 20 September 18th, 2005 04:40 PM
NAS spec D90 tune resistor help required UKlandyandy Defender Technical Discussions 8 May 7th, 2005 07:05 AM
Hella Light Bar Plastic end Cap 48vphantom Wanted 0 December 19th, 2004 12:53 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
Tdi Bumper End Caps? wicks Misc. Chit-Chat 2 December 19th, 2003 11:12 PM
