help! anyone know bolt size for alternator? - Defender Source
Old December 31st, 2010, 11:54 AM
paluskat
Tom Paluska
D110 200TDI
Noticed my alternator was wobbly - a long way from home. Seems that the lower rear bolt is missing. ??? Fell out, who knows. Only anchored bu front bracket. 200TDI in NAS 110. Anywhere I can find the specs for this bolt size?
thanks
tom
Old December 31st, 2010, 06:53 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
This sounds familiar. My alternator has tried to escape more than once. My parts catalogue seems to have an error in the specs for the bolts for the bracket. I just to go the local hardware store and get replacements. I think they are 8mm, and maybe 30mm long.
I discovered that the bottom bolt on mine is broken off. This doesn't help much as far as keeping the alternator firmly fixed in place. I have high hopes of finding the time this winter/spring to replace the timing belt and attending to the broken bolt problem and a few other things while I'm at it.
John Karlsson
Hope Valley, RI
Old December 31st, 2010, 07:31 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I think I just use 1/2 inch grade 8 on top, don't see why it wouldn't work on the bottom.
Robert Deniro
Old December 31st, 2010, 07:53 PM
John_Karlsson
John Karlsson
200Tdi?
John Karlsson
Hope Valley, RI
Old December 31st, 2010, 07:55 PM
Neil McCauley
Neil McCauley
Oh, well no v8. Sorry
Robert Deniro
Old December 31st, 2010, 08:05 PM
paluskat
Tom Paluska
D110 200TDI
thanks guys
I tried a M8 course thread and cut it to about 30mm actually and fit it with a lock washer. Not confident in cranking the bolt against the threads of the bracket though - feels a little off - maybe this is why the bolt was missing in the first place... Should be solid enough for me to get home and take it in for a closer inspection.
Wobble is fixed.
Appreciate the prompt replies.
Tom
alternator
Steering pump adj bolt size? DaveHuny Defender Technical Discussions 2 September 3rd, 2005 01:44 PM
Bolt size for Diff? UpnOver Defender Technical Discussions 3 July 5th, 2005 08:28 AM
TC cover plate bolt size? dmarchand Defender Technical Discussions 1 December 24th, 2004 06:59 PM
Oil pan drain bolt size?? mspell Defender Technical Discussions 1 October 2nd, 2004 12:09 PM
