Help, alternator swap on '97 - Defender Source
Old April 15th, 2005, 07:21 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
I finally got tired of the whining sound from my old alternator. I just received a brand new 120 amp today. Now, how hard is it to change it out. It on a '97. I changed out my last one, but that was on a '94. I am not all familiar with the serpentine belt. Any and all suggestion would be nice.
David
Old April 15th, 2005, 08:16 PM
EASY , take the belt off first, you only should need to take the tension off the tensioner pulley under the AC unit and you should be able to slip the belt off of that. Then remove the belt off of the Alt, pull the wires off the alt (keep track of what wire goes where) remove the 2 bolts that hold the alt on, and slap on the new one.
Old April 16th, 2005, 01:15 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
Thanks Mike for the help, didnt take me that much time.
David
97, alternator
97 Gas pedal questions shawnpalmer Defender Technical Discussions 3 May 5th, 2009 05:19 PM
R380 in an NAS 97 D90 Conversion? GYM Defender Technical Discussions 19 November 5th, 2008 07:21 PM
97 D-90 ST B-pillar rayfi Wanted 0 November 5th, 2008 12:56 AM
Wtb 97 D90 ECR Wanted 6 September 12th, 2008 08:50 PM
help / opinons on 97' ST januconn92 Misc. Chit-Chat 1 January 12th, 2004 12:16 PM
