Help! Accidentally touched two wires while installing carling hazard switch, car died - Defender Source
Old August 11th, 2013, 07:29 PM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
So this is dumb I know, but I had the car on while messing with installing a new carling hazard switch. Accidentally touched two of the wires, they sparked, and the car died. The car makes no noise when I turn the key now, and the AC and radio also do not work. Interior lights work fine, as does the clock and cigarette lighter. I check the fuses I thought it could have blown but there are all fine. Hopefully someone can lead me in the right direction!
Old August 11th, 2013, 07:32 PM
which two wires? that will dictate the fuse that failed. dont forget fuses under bonnet.
Mark Kellgren
KM4BOR
Old August 11th, 2013, 07:54 PM
bradfordish
Bradford
95 D90 SW #141
Forgot about under the bonnet... blew a 30 there. Thanks for the quick reply! Can I pick these up at my local autoparts store, or is this need to be ordered from Roversnorth?
Thanks Again.
Old August 11th, 2013, 08:28 PM
Standard fuses that can be found literally anywhere.
------ Follow up post added August 11th, 2013 08:28 PM ------
If it's one of the big ones, any autoparts store will have them.
Mark Kellgren
KM4BOR
ac, switch
MUD UK Hazard Switch Wiring sonoronos Defender Technical Discussions 13 February 27th, 2017 02:18 PM
Hazard switch problem jayz Defender Technical Discussions 12 July 8th, 2012 10:05 PM
hazard switch wiring Overlander Defender Technical Discussions 18 January 12th, 2007 08:09 AM
