Help! 200Tdi VDO EGT probe location - Defender Source
Old July 3rd, 2014, 10:02 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I have searched the forum, google, all the other forums and haven't found my answer. I purchased the VDO vision EGT gauge and probe. PN 310-153. Gauge is in fine but I can't figure out the best place to drill and tap the exhaust manifold. It looks like the probe is too long unless I go in the "V" between #2 & #3. Anyone wiling to post up some pics of their install of this gauge and sender? Thanks.
Old July 3rd, 2014, 10:32 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I drilled a tapped the manifold flange where the turbo mounts to the exhaust manifold
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 3rd, 2014, 10:38 PM
I wish somebody made a plate that goes between the turbo and the manifold that is threaded for a probe. Hint, hint for one of you machinist types..........
Old July 3rd, 2014, 10:46 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Best place would be in the first inches after the turbo ? Easy to drill an hole in the down pipe and install the probe with pre-pierce clamp. That's how we do it on airplanes.
Old July 3rd, 2014, 10:53 PM
Like here or higher up on the turbo housing?
Old July 3rd, 2014, 11:02 PM
roverman2010
1985 LR 90 200Tdi
But after the turbo you do not get the full EGT reading?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old July 4th, 2014, 12:52 AM
El Solis's Avatar
El Solis
Chris Solis
thanks everyone, Roverman...is that the same probe that I have? My concern in the depth of the probe (being too long).
Old July 4th, 2014, 07:33 AM
Don't put it after the turbo. The readings are not good there. Where shown or lower down on the manifold. The manifold is thick enough to drill and tap.
Old July 4th, 2014, 07:54 AM
I have seen them in both the 1st and 4th manifold runners, no bung just drill and tap the cast iron. Do not install post turbo. Things are considerably cooler post turbo and readings are of little value.
Old July 4th, 2014, 08:17 AM
I have seen them in both the 1st and 4th intake runners, no bung just drill and tap the cast iron. Do not install post turbo. Things are considerably cooler post turbo and readings are of little value.
Doug means exhaust runners
Mark Kellgren
KM4BOR
Old July 4th, 2014, 08:50 AM
Yep- hadn't had coffee yet.
Was up late watching weather channel. We have a contract on a house on the Carolina coast @ Glouchester right where Arthur came ashore across the Shackleford Banks-ie direct hit on the property.
Maybe Raub will post up a picture of his which is in the 4th cyl runner, ie great access.
Old July 4th, 2014, 09:14 AM
Mine is in the 1st. Not sure if I have a picture. It is easy to do there without removing anything...
Old July 4th, 2014, 09:18 AM
roverman2010
1985 LR 90 200Tdi
I have the VDO probe, you need the length in the gas flow.
Hoping all you East coast people are OK.
stay safe
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old July 4th, 2014, 09:46 AM
Please post up a picture. I need to instal an EGT but I'm not wanting to take everything apart to drill the hole.
Old July 4th, 2014, 10:34 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
X2
Thanks!
Old July 4th, 2014, 04:45 PM
A little hard to see behind everything. 1/8" NPT compression fitting.
ID:	98114   Click image for larger version
Old July 4th, 2014, 05:06 PM
Perfect pic John. Any concern about the metal bits that fall inside while drilling?
Old July 6th, 2014, 09:33 PM
El Solis's Avatar
El Solis
Chris Solis
Thanks everyone for chiming in! Really helps. One of the many reasons this forum kicks ass!
Old July 7th, 2014, 07:59 AM
Try and be careful to keep the pieces out. It is not a big worry in my mind.
Old July 7th, 2014, 08:16 AM
I put vaseline on my drill bit when I did mine but drillings will just going out the tail pipe, no real worries.
200tdi, tdi
200Tdi EGT Probe Adapter Plate? javelinadave Defender Technical Discussions 4 August 20th, 2016 09:45 AM
VDO Vision EGT pyrometer sensor installation. sundogcwolfe Defender Technical Discussions 10 September 25th, 2011 01:31 PM
EGT Location Overlander Defender Technical Discussions 7 October 20th, 2010 07:32 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 10:31 AM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 14th, 2007 11:16 PM
