Help! 200Tdi VDO EGT probe location - Page 2 - Defender Source
Old July 7th, 2014, 10:04 AM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Thanks for pics, John.
Old July 7th, 2014, 10:22 AM
Thanks!
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I put vaseline on my drill bit when I did mine but drillings will just going out the tail pipe, no real worries.
It's just the engineer in me, I personally would take it part to do it and have done so, there is no way you know for sure you got all the swarf out.
As for it blowing out the tail pipe yes but it first has to pass the exhaust turbine and the dump Vv
But each to their own
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 9th, 2014, 12:28 AM
DBrands's Avatar
DBrands
David Brandson
D90 Truckcab
Shop vac on the hole after youre done drilling and tapping? Should get most of it.
Old August 12th, 2014, 02:27 PM
NADA
Any pics of this being completed?
Old August 12th, 2014, 02:32 PM
the rover shop
shayne young
Pretty sure there were pics etc on my camel trophy build thread.. I did it to mine..and I'll be doing it to the new toy..but that's a diesel of a different kind..
Old August 12th, 2014, 03:31 PM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
Shayne, as your number 1 fan I looked and saw your pics. They helped.
Jonsey, i'll take some pics tonight. Nothing special. Looks like this one (stolen from the web)
But between 3&4 not 1&2.
They did it with the manifold on, so far no issues(about 1000 miles driven).
Old August 12th, 2014, 03:47 PM
NADA
Thanks Chris...BTW - Shayne doesn't need fans He has a big enough head!!!
Old August 12th, 2014, 03:48 PM
the rover shop
shayne young
I did it on the after turbo side... Some say to do it before the turbo.. Supposedly reads higher before turbo than after by 1-200 degrees.... Doing it after turbo is muuuuch easier.. No problems with dwarf etc..
Old August 12th, 2014, 04:27 PM
NADA
yeah but aren't you supposed to be concerned about the gas temp that is going into your turbo? Not out of it?
Old August 12th, 2014, 05:02 PM
the rover shop
shayne young
If the gases after turbo are too high then there's a fairly good chance the gases before it are too high... Turbo can't generate more heat into gases.. As mentione.. After turbo is about 1-200 degrees cooler... I still see a nice rapid response to turbo temps when pulling hard etc... If it starts getting too high---1200 degrees I back off" but haven't had to yet,,, not even pulling up from Skagway Alaska"
Old August 12th, 2014, 06:17 PM
El Solis's Avatar
El Solis
Chris Solis
The nice thing about Shayne and his big head is that he knows it so telling him doesn't affect the size. Although I hear rumors he had to get a bigger rig to fit it in
Old August 12th, 2014, 06:26 PM
NADA
so maybe two gauges!!!! he with the most wins right mate
Old August 12th, 2014, 06:36 PM
the rover shop
shayne young
Just one of the many services I offer bitches.... And Chris.. Who do you call when you want an answer... Yeah, you know it sistah...
Old August 12th, 2014, 06:46 PM
El Solis's Avatar
El Solis
Chris Solis
just wait until you get stabbed/shot or need those hemorrhoids removed Shayne (cause you know it's coming) and then we will see who you call!! Bitches!!
Old August 12th, 2014, 07:04 PM
the rover shop
shayne young
Speaking of hemmeroids... You'd do that for me buddy...??? I guess you saw enough of my ass end on those trails and long hills at the meet.... You're familiar with my ass.. Well at least my camels ass...lol.."
Old July 16th, 2016, 11:18 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
Originally Posted by roverman2010 View Post
I drilled a tapped the manifold flange where the turbo mounts to the exhaust manifold
John, thanks for the post! Just finished tapping mine in the same location. Worked like a charm. Of note, was able to do it in place without removing anything. Started out drilling it and then before punching through started up the engine which blows the swarf out the hole as you are drilling it out. Drilled a progressive hole, and worked up to the 11/32's.
Old March 1st, 2017, 10:12 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Just ordered EGT gauge. Removing my turbo and manifold to do a headgasket. Thinking about welding a bung instead of tapping since it is apart anyway. Thoughts? Goal is to put it in a the 4-1 collector area.
Which cylinder on 200tdi's runs the hottest? #4?
Old March 1st, 2017, 11:39 AM
Just drill and tap the manifold below the outlet flange. The thermocouple gets the flow from all cylinders. 1/4" NPT. No point making life hard by trying to weld something onto a cast iron manifold. You ruin it, you can't replace it... There is a lot of meat for tapping.
Old March 1st, 2017, 11:48 AM
AdamSanta85
91' D90 200TDI
Cool. I will just put it in the 4-1 collector. Yea welding to cast is far from ideal, but figured it would be "cleaner". Tap it is.
We used to put EGT gauges on Subaru's on the leanest cylinder (#4 due to their factory fuel rail design). That is why I was asking about that.
200tdi, tdi
200Tdi EGT Probe Adapter Plate? javelinadave Defender Technical Discussions 4 August 20th, 2016 10:45 AM
VDO Vision EGT pyrometer sensor installation. sundogcwolfe Defender Technical Discussions 10 September 25th, 2011 02:31 PM
EGT Location Overlander Defender Technical Discussions 7 October 20th, 2010 08:32 PM
EGT/ Pyrometer sender best location ???? Uncle Douglas Defender Technical Discussions 6 August 9th, 2008 11:31 AM
200tdi EGT probe location ... Retrofit Defender Technical Discussions 3 May 15th, 2007 12:16 AM
