Help 110 Pulls right then left - Defender Source
Old October 15th, 2015, 06:15 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
So today I left twice for Uwharrie, but had to return home both times.
Symptoms: Pulls right about 10 inches on acceleration and about the same left when you let up completely.
Took out shims on the swivel balls that removed play
Replaced a steering U-joint that had play
Adjusted the steering box that had play
When someone moves the steering wheel back and forth cannot see any play in the pan hard rod or track link bushings or radius arms.
Any suggestions?
This is scary at 60 MPH.
RDavisinVA
Old October 15th, 2015, 06:19 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Sure the trailing arm bushings aren't warn/disintegrated?
Old October 15th, 2015, 06:38 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by down_shift View Post
Trailing arm bushings warn/disintegrating or perhaps one split off if movement is that bad.
That makes perfect sense.
I do not have new ones here, but we have 2 disco I parts trucks.
Wonder if they interchange with the 110?
RDavisinVA
Old October 15th, 2015, 07:11 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Disco 1 ones are the same.
When I had a polybush trailing arm bushing fail it had similar symptoms. look at it, it may be clearly disintegrated
Old October 15th, 2015, 07:21 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Had the same issue and did castor correction bushings and it went away. My truck was +2"
Defender 110
Old October 15th, 2015, 09:23 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by D90user View Post
Disco 1 ones are the same. When I had a polybush trailing arm bushing fail it had similar symptoms. look at it, it may be clearly disintegrated
Looks like the trailing arm arm connection at the diff end are off center (skewed to one side) indicating a worn out bushing.
Will pull from a disco I and get back on the road in the morning...
Thanks all.
RDavisinVA
Old October 15th, 2015, 09:25 PM
Originally Posted by rdavisinva View Post
Thanks all.
Robert - what turned out to be the cause of the problem?
Old October 15th, 2015, 09:55 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Will find out, but not sure yet
RDavisinVA
Old November 2nd, 2015, 09:00 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
So my polybush kit showed up this week and this weekend replaced the rear trailing arm bushings.
The axle end was a royal pain to fit.
It was tight enough, but the "genius" who designed the axle end bushings decided to put a small lip that fits over the side of the end of the outside of the trailing arm.
It kept folding over, first on the outside edge and then inside the hole.
This lip is not part of the OEM bushing configuration.
I am of the opinion that if you torqued down on the through bolt, it would seize the sleeve the bolt fits through and keep the bushings in place where they would then tear and disintegrate.
So I tightened them less than full hoping it will be tight enough not to allow the rear axle to twist, but loose enough to move.
So the steering sway is about 95% gone.
Think the remaining swaying is due to the front bushings which I will get to in the future.
RDavisinVA
Old November 2nd, 2015, 09:40 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Just out of curiosity, what is the air pressure in your tires? Possibly you may forgot to properly air up evenly after a trip? I had similar issue but it seems to be gone after even'ing out the tire pressure.
Old November 2nd, 2015, 09:49 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
45 PSI across all 4
RDavisinVA
Old November 3rd, 2015, 01:10 AM
DailyDrivenDefende
Michael
I would try torquing it down to spec and see if the problem goes away, cheap enough to try.
Tight enough isn't tight enough sometimes specially on suspension components. I am sure we all have a share of story about loose bolts or nuts. Unfortunately, bushings are designed to twist and get mangled unlike some joints ie heim joints or some sort of flex joints that are designed to articulate.
Old November 3rd, 2015, 01:44 AM
atpick's Avatar
atpick
Andy
1990 110
Any suggestions?
I had this exact same problem on a previous 110 I owned. I made two simple fixes an the problem was solved.
1) The front tires were "toed in" too much evidenced by uneven tire wear. We adjusted the track rod to toe them out.
2) The bolts where the left and right rear shocks connected to the body were loose.
Once we corrected these items the pulling stopped. I also installed an OME steering damper but I'm not sure this had any effect.
Hope this helps.
Cheers,
Andy
110, ht
Parcel tray owners manual pocket door pulls o2batsea Wanted 0 September 28th, 2014 11:24 PM
Hanjin Shipping pulls out of Portland SMac Misc. Chit-Chat 0 October 20th, 2013 12:32 AM
Junkyards/Pick and Pulls Ray_G Misc. Chit-Chat 5 February 6th, 2013 07:26 PM
Repair: 110 Back seat release pulls RoverDude Defender Technical Discussions 1 May 3rd, 2011 10:59 PM
95 D90 Pulls left kolvedic Defender Technical Discussions 6 August 21st, 2005 06:01 PM
