Hella wiring retard - Defender Source
Old March 17th, 2007, 12:27 PM
Andrew Vick
Andrew Vick
95 D90
Hella wiring retard
Hopefully someone can help. I got a set of Hella HID lights used, and I've seen them work. The came with the ballasts, and basically there's a blue and a brown wire coming off of each. I got a Hella wiring harness, and attempted to hook them up using their instructions. Basically grounded all of the browns and hooked the blues together. There are 2 green wires coming off the switch. Once goes to the fuse block, and I have no idea what to do with the other. It says to wire it to the high beams, but I want to be able to turn these on whenever I want, main lights on or not. I've got power to the fuse block, but no power at the switch or the blue wires to the lights.
Any help is greatly appreciated.
Old March 17th, 2007, 12:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can just wire them together or take it to the battery for constant power.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 18th, 2007, 08:45 AM
Andrew Vick
Andrew Vick
95 D90
So either wire the greens together, or run the extra green back to power? If so, makes sense. Sorry for the poor writing earlier. It was one of those "I'll be done in an hour" situations, and though I had started at 8, it still wasn't done by 10.
Reading more, I think you do mean to take the extra green back to power. If so, do I have to go directly to the battery, or could I go to the hot side of the starter, for example? Is that always hot, or only when cranking the engine? Thanks for the help!
Old March 18th, 2007, 08:49 AM
I ran the "high beam" wire to constant power (direct to the battery) and then encountered a different problem. It turns out that the generic hella harness came with a 10 amp fuse, and the pair of 4000's kept blowing it. Sub'd in a 20 amp fuse and everything works great. I should have bought the hella 4000 wiring harness and then I would have gotten the right connectors on the end and not had to splice. That was a typical case of Rovers North providing half-ass information about the stuff they sell.
Old March 18th, 2007, 10:20 AM
Andrew Vick
Andrew Vick
95 D90
I will do the same, and check the fuse that's in there. The harness that I have is for the 4000's, but the HID's have their own harness that didn't come with the used lights I have. From my understanding, the HID's draw far less power, so maybe the fuse won't be the issue. This should work, and I'm looking forward to having them light up after having had the lights installed for 3 months with no power
Mission accomplished. Thanks for the help!
Old March 18th, 2007, 01:09 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Same thing happened to me, but I was too lazy to deal with it so I hooked the lights directly through a 50amp switch that I had lying around and discarded the fuse all together. Has worked fine for 3 years now.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
wiring
hella 4000 wiring bjenk Defender Technical Discussions 11 November 23rd, 2011 05:43 PM
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
hella city light wiring bjenk Defender Technical Discussions 10 March 8th, 2005 08:08 AM
Hella 3000 oem wiring kit 48vphantom Wanted 0 February 18th, 2005 01:13 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
