Hella wiring problems... - Defender Source
Old July 18th, 2004, 01:50 PM
mlw911
Michael Walter
1995 D90 ST
Each time I turn on the hella's, I blow out the fuse for whatever source I am powering off of for the light switch. I started with the high beams like the intrux said but blew the fuse for the high beam when I switched the hella's on. Then I switched the light switch power source to the running lights and the fuse for the running lights blew. I have rechecked everything and it seems straight. Could an improper ground on the lights themselves be causing this. I ran them to a screw right by the hood release, but now I am wondering if it's aluminum or other. Help!!!
Old July 18th, 2004, 05:06 PM
Big lights use big electricity. When I wired up my lights I ran a wire from the battery to a relay. I then grabbed power from the rear wiper motor switch (I too have a soft top and the wiring is behind the cover betreen the vent handles) to power the switch to run the relay. It works like a champ & I have never burned a fuse.......Dave
problems, wiring
hella 4000 wiring bjenk Defender Technical Discussions 11 November 23rd, 2011 05:43 PM
hella wiring harness rover4x4 Defender Technical Discussions 19 March 6th, 2006 08:29 AM
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
hella city light wiring bjenk Defender Technical Discussions 10 March 8th, 2005 08:08 AM
hella wiring diagram Campbell Defender Technical Discussions 1 May 1st, 2004 02:28 PM
